Most studies involving finger jointed studs were conducted in environment of 11% humidity.
What happens in South Texas environment? Many days over 100 degrees and low humidity. Wood shrink and Detorate pulling loose from adhesive? |
| Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
[QUOTE=Unregistered;613872]Most studies involving finger jointed studs were conducted in environment of 11% humidity.
What happens in South Texas environment? Many days over 100 degrees and low humidity. Wood shrink and Detorate pulling loose from adhesive?[/QUOTE] I'm not from south Texas but that it would have to be a rare day and special situation before interior RH's got that low!! It's getting real dry in a home when the RH gets below 20-25%, Before it gets lower than that, someone's going to be buying a humidifier. Checked historic monthly average RH's for Odessa-Midland and the lowest outdoor is 38-40% in March-April. |
Try looking lower...
San Antonio and below. This area breaks all the rules. Seriously House shopping I found a lot of finger jointed studs were being used in the houses. I grew up in the building industry. I question the use of these studs on load bearing walls. Closets OK. I found lots of houses 5 years old are not holding up well. In one house I looked at the Stairwell was giving in. Behind the sheet rock you could see finger jointed studs that had cracked. |
[QUOTE=Unregistered;614271]Try looking lower...
San Antonio and below. This area breaks all the rules. Seriously House shopping I found a lot of finger jointed studs were being used in the houses. I grew up in the building industry. I question the use of these studs on load bearing walls. Closets OK. I found lots of houses 5 years old are not holding up well. In one house I looked at the Stairwell was giving in. Behind the sheet rock you could see finger jointed studs that had cracked.[/QUOTE] Not the lack of humidity....... In Corpus Christi, lowest monthly average RH was 62% from 38 years of data. Up where I live, it can get quite dry in the winter. Infiltrating or HRV supplied air outdoor at -4F & 90% RH when heated to 68F is about 5-7% RH.......now that's getting dry.......but the lowest RH I've ever measured in a house was around 23- 25% since house activities, plants, pets, basments continually add moisture to the air. |
