AskNACHI.org » Framing Inspection once the walls are up (posted by Lisa Leach)
Old 7/16/07, 4:13 PM
AskNACHI.org AskNACHI.org is offline
Automated messenger from AskNACHI.org
Please Note: AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Framing Inspection once the walls are up (posted by Lisa Leach)
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]Lisa Leach[/B] (from Maricopa, Arizona). [/ASKNACHI] was wondering if I could get an expert opinion please?
We were supposed to have a framing inspection and we were not notified and the house is finished.
The builder said they will cut 6 holes in the wall so that we may complete our framing inspection.
For a 2 storey 4014sq ft house - is this reasonable? I can't see how we can have a proper framing inspection now that the house is complete.
Old 7/16/07, 4:22 PM
rwand1 rwand1 is offline
Default Re: Framing Inspection once the walls are up (posted by Lisa Leach)
You can't have a proper framing inspection by cutting random sections from the walls/ceilings. Those access ports only show whats visible in the area of the cut outs.
Ideally as you realize the idea of a framing inspection is to have the inspection before any drywall is installed.
In my area the municipal building inspector has to approve the framing before the drywall goes up.
I think I would be asking the builder for a warranty on the framing considering he did not comply with the agreement you have with him.
Old 7/16/07, 6:14 PM
As Ray said, it is now impossible to do a proper framing inspection. Cutting 6 holes in the drywall to check the framing of a two story house is like looking in the trunk of your car to find a problem with the transmission.
Abraham Lincoln
Old 7/16/07, 6:34 PM
GARY L. RUSK GARY L. RUSK is online now
Lisa
Raymond is right you can’t do a framing inspection on a finished home unless they remove all the drywall, find a NACHI inspector and have him inspection what he can (ie attic, crawlspace, basement, any unfinished spaces and the home in general) this will give the inspector somewhat of a reference/ideal as to whether or not you have a contractor that is good, bad or somewhere in between. As Raymond said ask the builder for a warranty on the framing and any damages that may occur. Have your layer check the warranty, most aren’t worth the paper there written on.
Good Luck on your new home!!!
Gary L. Rusk
[URL="http://www.hsspropertyinspection.com/"]HSS PROPERTY INSPECTION[/URL]
Old 7/18/07, 3:13 AM
whandley's Avatar
whandley whandley is offline
Please Note: whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Speak to the local building official responsible for the rough framing sign off. It is possible to make access to critical framing areas for further inspection. For example, if you pull an "As Built" permit on a second story addition constructed with out proper permits, the building official will ask for plans and determine high load and or stress areas. They will then ask for these areas to be made accessible for further inspection. It's not perfect, but it's better than nothing. You may for instance be concerned with structural bracing and or simpson strong tie hardware installation at a second story living area above a garage opening.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274
