AskNACHI.org » furnace common venting
Old 11/3/09, 10:09 AM
Unregistered
Guest
Posts: n/a
Default furnace common venting
I currently have 80,000 btuh (output) 80% sealed combustion furnace and a 40 gallon natural vent water heater. My old chimney vent is 5 or 6" not sure (I'm not at home).
My furnace is vented as per instructions with PVC pipe with proper pitch and termination fitting outside (20' away from furnace) and the water heater is vented up the old stack.
Due to recent home addition I would like to move my furnace vent to the old stack with the water heater. My plan is to leave the air intake where it is but move the exhaust.
The water heater is about 7' away from the old stack and the furnace is within 3'.
If the suggestion involves joining the two vents how do I transition from PVC to vent pipe??
Any ideas would be helpful.
Thanks, Dave
Find an InterNACHI certified Vermont Home Inspector (and anywhere else in North America)
Old 11/4/09, 8:59 PM
Patrick Bolliger's Avatar
Default Re: furnace common venting
Dave,
It sounds like your trying to connect two different appliance types using a common chimney with this remodeling project.
Lets see if we can clear up some terms first:
I take it stack is what you are referring to as a chimney?
Is this chimney a masonry "brick" chimney? or a metal chimney?
Is the vent or venting by way of a metal flue pipe from the Water heater?
The basic concept is to exhaust the products of combustion properly and that means following requirements such as the appliance manufacture outline within the installation manuals that come with the appliance. To make changes / modifications that fall outside these requirement can lead to serious problems such as improper venting, back drafting or even worse Carbon Monoxide hazards. Poor chimney draw can also seriously affection performance of your appliance in certain cases so this is not something we can take lightly.
These science of proper venting is critical to a safe home so proper installation is first and foremost important and any changes to a vent system need to be performed by a professional who can properly configure venting.
Generally "Plastic" exhaust piping is used for high efficiency appliances (90 %+ efficiency, category 4) with positive pressure venting that require there own exhausts due to a higher pressure venting then the lower pressure (higher heat) natural draft (atmospheric) appliances like your water heater. In addition to this is the fact that the high efficiency exhaust have low temperatures that PVC or "plastic" can be use for the exhaust. So this means we cannot mix the two types of exhausts into a common chimney!
The "natural draft" or atmospheric draft system, lower efficiency (negative pressure) appliances with metal flues go to masonry ( hopefully lined) chimneys or metal chimneys that relies on the heat or "draw" created for venting. So what your aiming for is not recommended or advisable to do. I would look at the furnace documentation and contact a qualified heating contractor for assistance and information on what can be done to accommodate your remodeling plans. People have paid with their lives by not properly venting appliances..
Please play it safe..
Regards,
Pat
Old 11/5/09, 9:02 PM
James E. Braun, CMI's Avatar
It is not recommended to combine the two vents together for many reasons. Be safe and run them seperate.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
