AskNACHI.org » Gable Vent (posted by Jim Vaughn)
Old 7/10/08, 7:04 AM
AskNACHI.org AskNACHI.org is offline
Automated messenger from AskNACHI.org
Please Note: AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Gable Vent (posted by Jim Vaughn)
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]Jim Vaughn[/B] (from Rome, GA.). [/ASKNACHI]
I inspected a home with vinyl siding. The builder used soffit vent material for the gable vent. Is this allowed or proper?
Old 7/10/08, 7:46 AM
David P. Valley's Avatar
Default Re: Gable Vent (posted by Jim Vaughn)
[quote=AskNACHI.org][asknachi]This question was posted on [I]AskNACHI.org[/I] by [B]Jim Vaughn[/B] (from Rome, GA.). [/asknachi]
I inspected a home with vinyl siding. The builder used soffit vent material for the gable vent. Is this allowed or proper?[/quote]
No. And to make matters worse, gable end vents shouldn't even be used with today's insulation requirements of R-39 value, as this hot cavity will deteriorate any shingles above. If the roofing material is asphalt shingles, the attic cavity will need ridge and soffit vents in order to prolong the life of the asphalt shingles.
See....[URL="http://www.masscertifiedhomeinspections.com/?D=116"]ATTIC VENTILATION[/URL]
Old 7/10/08, 9:36 AM
David A. Andersen's Avatar
Yes, they do it all the time in the south.
It reduces potential ventilation and does not comply with the ventilation standards. The net free area can be challenged to what ever building standard used for your area.
It can be used, but will require other "upper" vent systems to comply. Ridge vents, power vents etc. as David pointed out.
BPI# 5015804
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274
