AskNACHI.org » gfci
Old 11/27/09, 10:13 PM
rmelville rmelville is offline
Default gfci
Are all the outlets in the kitchen supposed to be gfci?
Find an InterNACHI certified Alaska Home Inspector (and anywhere else in North America)
Old 11/27/09, 10:16 PM
Mark E. Northrup's Avatar
Mark E. Northrup Mark E. Northrup is offline
Default Re: gfci
Depends on the year of the structure and the area that the structure is located in.
House 2 Home LLC
503-602-1420
HomePros@House2HomeLLC.ORG
Protecting Peace of Mind One House at a Time
IAC2 Certified
IR Certified
A favorite place on Google Maps
Old 11/27/09, 10:34 PM
Default Re: gfci
i believe it is 6 feet from the sink and any outlets that are over the counter.
Old 12/13/09, 4:51 PM
Default Re: gfci
Russell,
No, not all receptacles in a kitchen are required to be GFCI protected. Only the ones serving the countertop requirments.
Now 6' ( as far as dwellings go ) only came into play with regards to wet bar, utility and laundry sinks. However, in the 2008 NEC in OTHER than dwellings saw the requirement of GFCI protection on ALL sinks within 6' come into play which was a major change for the NEC.
Now if you are speaking of a Kitchen OTHER THAN A DWELLING then all 15 and 20A 125V receptacles outlets would require GFCI protection within the kitchen space and that would include all.....not just any countertop devices. Remember however that we are talking about an OTHER than dwelling environment.
Paul W. Abernathy
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
