I am working in Afghanistan and we are installing LSS units
There units (Latrine Shave Shower) are ready made units in a normal size shipping container My question is, Is there a code requirement to ground the container? The panel that feeds this unit has a ground rod. Does the code require a separate ground for the metal container. It sits off the ground on concrete blocks. Is it just grounded just for lighting protection or is a bond needed from the panel also? Thanks, |
Since no one else has answered I'll give it a stab at it and maybe someone else will give more detailed info. I think the metal structure has to be bonded. This is so there is only one path to ground and all metal has the same potential.
