Chimney exits the roof more than 10 feet from the hip of the roof. The chimney height is more than 3 feet to the chase. There are no other obstructions on the roof. According to the respective installation manual this what I have done. Is this correct?
An HI is a non-member guest and is in no way affiliated with InterNACHI or its members.
[QUOTE=Unregistered;835404]Chimney exits the roof more than 10 feet from the hip of the roof. The chimney height is more than 3 feet to the chase. There are no other obstructions on the roof. According to the respective installation manual this what I have done. Is this correct?[/QUOTE]
If you have to come to a board like this to enquire if you did an installation of a wood heating appliance or chimney correctly, you probably shouldn't have done it yourself. Hire a certified pro; you're playing with fire. |
