AskNACHI.org » Heating system
Old 3/20/09, 2:42 PM
Unregistered
Guest
Posts: n/a
Default Heating system
Hi,
The inspector found a full bathroom with no connection to the heating system. I think this shoud be repair by the seller. It's correct?
Thank you,
Esteban Polo
epolo1@ec-red.com
Find an InterNACHI certified Delaware Home Inspector (and anywhere else in North America)
Old 3/22/09, 1:54 AM
Joseph Tribuzio's Avatar
Joseph Tribuzio Joseph Tribuzio is offline
Default Re: Heating system
That would be the job of your Real Estate attorney to advise you on that issue.
Joseph Tribuzio 708 453 8447
Tribuzio Home Inspection Services
CHICAGOLAND, ILLINOIS
www.thishomeinspector.com
ID# NACHI07062507
IL Lic#450.003128
Radon lic# RNIT2008216
Home Inspector Pro Software
HIP Web Hosting
Old 3/22/09, 9:51 AM
David A. Andersen's Avatar
Someone posted here that a bathroom does not "require" heat because of "habitable room" criteria in some State interpretations.
You need to check at your local level, not here.
Your inspector was correct in reporting it in any case. But that does not mean it requires repair.
BPI# 5015804
Old 3/22/09, 10:24 AM
kluce kluce is offline
Please Note: kluce is a non-member guest and is in no way affiliated with InterNACHI or its members.
I can see somebody interpreting it that way but I would think that's more the exception than the rule (as Mr. Andersen indirectly wrote in his last statement).
I would agree with Mr. Tribuzio that who pays to have the heat run installed would be between the buyer and the seller and how the contract was written. Knowing if this is an acceptable practice in that area (I would think) would play a role in the negotiations.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
