Have a Mfg home I inspected. 4 years old, leaks into the home on both side walls (faces west.) The home is in Montana (Kalispell) It do get cold and snowy there. The overhang is 6-8 inches. Roofing looks good. Have neot been there while leaking. Could this be a mfg problem?
| Find an InterNACHI certified Kentucky Home Inspector (and anywhere else in North America) |
Yes
May also not be a mfg problem. You have not provided location of leaks within the building envelope other than saying leaks into the home on both side walls. could be from hammer holes in the exterior walls, don't know because you have not provided enough info Last edited by jmoore5; 8/20/09 at 11:18 AM.. |
It is very hard to say from the information that you have given us. Your best bet is to locate a home inspector in your area and talk to them, and possibly have them look at the home and help point you in the right direction.
Ian Niquette Square One Home Inspection Markesan WI 53946 www.squareonehomeinspection.com Active Rain Network What we've got here is......failure......to communicate.....
Ian,
The OP said he/she inspected the property. |
[QUOTE=jmoore5;549121]Ian,
The OP said he/she inspected the property.[/QUOTE] You are correct, sorry for the oversight. Ian Niquette Square One Home Inspection Markesan WI 53946 www.squareonehomeinspection.com Active Rain Network What we've got here is......failure......to communicate.....
