AskNACHI.org » Home Inspector Kansas City
Old 6/25/09, 2:15 PM
David Moriconi's Avatar
David Moriconi David Moriconi is offline
Default Home Inspector Kansas City
M3 Real Estate Inspection, LLC
david @m3inspect.com
www.m3inspect.com
Welcome to M3 Real Estate Inspection,LLC a Premier Home Inspection Kansas City Company.
M3 Real Estate Inspection,LLC provides greater Kansas City Home Inspection services with the knowledge and experience gained from inspecting hundreds of homes in Missouri. We help clients by informing them to the conditions of the house which may include hidden problems. M3 Real Estate Inspection,LLC is a trusted Home Inspector Kansas City Company that also provides Radon Testing and Mold Testing.
Choosing the right home inspector can be almost as important as choosing the right home. Why? Because many homes - even new ones - have defects that you may not notice. A skilled Home Inspection Professional such as M3 Real Estate Inspection, LLC has the training and experience needed to look for visual signs of defects in your new home. These defects, if not detected and repaired prior to closing, can cost you, the new homeowner, thousands of dollars in repair bills.
It is very important to know the true condition of the house, so you can determine its true value to you. I will not make the buying decision for you, but the inspection can provide you with the information needed to make the decision wisely. You will want to know: How many problems? How serious are the problems? What will it cost to correct them? and Do I absolutely need to correct the problems or can I live with them?
I strongly encourage all of my clients to be present at the inspection. You should feel free to ask me any questions you may have during the inspection process. I will point out problems and explain them to you. I will also show you the good points of the house as well. Plus, I will explain what routine maintenance is needed to keep the house in top condition. This will help you to get the most benefit from the inspection and gain the most understanding of the systems that make up your home, and how to maintain them.
Inspection services offered:
• Mechanical & Structural
• Environmental Testing
• Radon Testing
• Mold Testing
• Listing Inspections
• New Construction Inspections
• Home Maintenance Inspections
• Commercial Inspections
• Flexible Scheduling
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274
