AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]George Johnson[/B] (from Gary, Indiana). [/ASKNACHI]A 60 amp electrical service panel at a 2,800 square foot home would be: a. undersized; b. oversized; c. the right size
In the bathroom, a good location for a permanently installed ceiling heat lamp is: a. over an empty space so as not to overheat anything; b. over the path of the bathroom door; c. over the toilet seat to keep warm Isolated links on light fixture pull chains prevent: a. the user from being shocked or b. overheating of the fixture Fuses do NOT provide protection against: a. short circuits; b. lightning surges; or c. large ground faults When a well pump comes on and off quickly, this is a: a. short cycle; b. an intermediate cycle; or c. a long cycle Exterior plumbing stack vents should be at least 3 feet above operable doors and windows. True or False When inspecting a boiler, always test the air bleed valves on the radiators. True or False The purpose of spacing between the exterior deck floorboards is to allow rainwater to pass through. True or False ; or Other reason |
[quote=AskNACHI.org][asknachi]This question was posted on [I]AskNACHI.org[/I] by [B]George Johnson[/B] (from Gary, Indiana). [/asknachi]A 60 amp electrical service panel at a 2,800 square foot home would be: a. undersized; b. oversized; c. the right size
In the bathroom, a good location for a permanently installed ceiling heat lamp is: a. over an empty space so as not to overheat anything; b. over the path of the bathroom door; c. over the toilet seat to keep warm Isolated links on light fixture pull chains prevent: a. the user from being shocked or b. overheating of the fixture Fuses do NOT provide protection against: a. short circuits; b. lightning surges; or c. large ground faults When a well pump comes on and off quickly, this is a: a. short cycle; b. an intermediate cycle; or c. a long cycle Exterior plumbing stack vents should be at least 3 feet above operable doors and windows. True or False When inspecting a boiler, always test the air bleed valves on the radiators. True or False The purpose of spacing between the exterior deck floorboards is to allow rainwater to pass through. True or False ; or Other reason[/quote]a. b. and or c. |
Is this an interview? I get the feeling you already know the answers. . .
some one is looking for answers to the NACHI exam
Is this a quiz? If I'd known there was gonna be a test, I'd have studied...
If a tree falls in the woods and there is nobody around to hear it does it still make noise?
A: YES B: NO C: Only a blonde can hear it. |
[quote=rromoser]If a tree falls in the woods and there is nobody around to hear it does it still make noise?
A: YES B: NO C: Only a blonde can hear it.[/quote] C: That's an ASHI answer |
jbreazeale is a non-member guest and is in no way affiliated with InterNACHI or its members.
If a poster posts a post of questions from the NACHI exam without explanation, then the poster posting is
A. Fishing for answers B. A confused ASHI guy C. Just plain dumb D. All of the above Ok, I'll bite. Yes, go ahead and test those bleeder valves, especially on the lower levels of the building, and more especially if they look a little rusty. Bring a mop. |
