AskNACHI.org » "Hum" in house
Old 6/4/10, 9:41 PM
Unregistered
Guest
Posts: n/a
Default "Hum" in house
I have a low pitch pulsing humming, for lack of a better explanation, throughout my house. I hear it from the basement through the second floor. Hear it different times of the day, seems loudest around 4 to 6 AM. It's not a constant sound, there are times when it's not audible. There doesn't seem to be a pattern. THe hum can not be heard in the walls or pipes. I've had the power turned off to the house, the water main in the home turned off and still hear the hum. The hum gets so loud it awakens me even with a white noise machine turned on and ear plugs in. What can I do to find the source of the noise? Who do I call? Electricians, plumbers, roofers have all been unsuccessful at finding anything. Help, I'm sleep deprived and frustrated. This has been going on since December.
Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/4/10, 10:46 PM
Darin Redding's Avatar
Darin Redding Darin Redding is offline
Default Re: "Hum" in house
Sure your imagination is not running away with you?
Darin Redding, CPI
Housecall Property Inspections
san diego home inspection
rental inspection | warranty inspection
Facebook Like
darin@sandiegohomeinspect.com
619-663-8740
home inspector in San Diego, Carlsbad, Poway, La Mesa, El Cajon, Chula Vista.
Old 6/4/10, 11:17 PM
Bob Elliott's Avatar
Maybe from outside transformer
Old 6/4/10, 11:21 PM
James H. Bushart's Avatar
It could be the ghost of Linda Lovelace....
Had a guy, once. who thought he had a short in his hard wired smoke detector. It kept going off at odd times, says he. Turned out to be his hearing aids "chirping" from high volume.
Are you the only one hearing this sound?
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 6/5/10, 7:32 AM
Wayne B. Wilson's Avatar
turn the power off, the water. Listen. next check for pests. have you seen any droppings around the outside of the home in corners? tree limbs on the home? when you shut the water to the home make sure it is at the street
if you have gas get someone to hold on to the pipe In short do some investigation for Vibration. BTW if you had any ultrasonic sonic detectors or devices installed and you do have hearing Aids there could be a frequency problem . hope this helps.
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 8/20/10, 7:38 AM
Unregistered
Guest
Posts: n/a
It may be infrasound. This is a little know low frequency sound wave. Most people can not hear it. I experience at my home all the time. It is probably not coming from your home. My wife thought I was crazy, until one day the blinds were rattling. Infrosound clings to the ground, it does not loose its intensity as it travels along the ground. Because of its ground clinging effect, infrasonic source can not be located without special appliances. The only thing that works for me when I sleep, is using a small fan, high speed, to mask the sound. The sound appear more active at night, although it may not be heard because of other daily noise activity. From my research into this matter, this sound could be coming from up to hundreds of miles away! Look it up on the internet.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
