Why in a 4-point inspection is 15 years used for the life expectancy of a a shingle roof, when I have 25 year shingles. Please call me 941-924-7036
| Find an InterNACHI certified Alabama Home Inspector (and anywhere else in North America) |
Shingles are like tires. They never get their expected life, especially down here in Florida due to the intense heat. Other factors also play into when a roof will need to be replaced, not just the life expectancy of the shingles.
Because the normal life for a 3 tab shingle is 12-15 years. Shingles never last as long as the manufacturer states in Florida.
Greg Bell Titusville, Fl 02111507 Serving Central Florida
The following factors affect the lifespan of roof-covering materials
- Roofing material quality: Better quality materials generally last longer. - Installation method: Improper installation may reduce lifespan. - Number of layers: Roofs installed over existing roofs will have reduced lifespan. - Structure orientation: South-facing roofs will have shorter lifespans. - Degree of roof slope: Flatter roofs will have shorter lifespans. - Climate zone (snow & rain): Harsh climates shorten roof lifespans. - Temperature swings: climates with large daily temperature differentials (within 24-hour cycles) will shorten roof lifespans. - Homesite conditions (overhanging tree branches, wind, etc.) - Roof color: Darker roofs absorb more heat which shortens roof lifespan. - Elevation: Homes at higher elevations are exposed to more ultra violet (UV) light, which shortens roof lifespan. - Home orientation: Roofs which receive more sun deteriorate more quickly than roofs which receive less sun. - Roof structure ventilation: Poor ventilation shortens roof lifespans. - Quality of maintenance: Poor maintenance will reduce lifespan. |
