AskNACHI.org » Marketing
Old 12/23/10, 9:17 PM
Eric Waldron Eric Waldron is offline
Please Note: Eric Waldron is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Marketing
Hello fellow inspectors,
I was visiting a friend in an apartment complex and discovered many issues with the complex that are unsafe. The apartments are an older brick type and have brick sided carports. The tops of the carports are being used as decks for individual apartments. The carport deck is concrete panels held together with steel bolts and square washers that are rusting. The side parapets for the brick is obviously leaning out and some of the bricks have already fell from the edges. It is only a matter of time before it fails completely.
That is not all. Electric wire has been run to feed lighting for the underside of the carports that is not in conduit and does not appear to be exterior grade wiring.
My question is: How could I put together a proposal that would convince them to allow me to do a thorough inspection of the complex with suggestions for remedies?
We are looking at 30 or more 6-8 Dwelling units.
I really have not even looked that close at them yet.
Any suggestions?
Eric
Old 12/23/10, 9:34 PM
James H. Bushart's Avatar
Default Re: Marketing
Step one....qualify for NACHI membership.....Step Two.....join....Step Three.....(Let me know when you finish Step Two)....
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
