AskNACHI.org » mitigation system in pennsylvania
Old 6/8/09, 5:44 PM
Unregistered
Guest
Posts: n/a
Default mitigation system in pennsylvania
My question is about my neighbor's radon mitigation system that is on the outside of his house. I don't want to question my neighbor before I know if I've got a legitimate concern.
Our houses are about 15 ft apart and aside from the white pipe you wouldn't know it was there. However he recently added a back room and now it sounds sort of like a pool filter or one of those electric neon signs. The pipe was above the old roof line but the new roof is maybe 3-4 inches above it now. I wanted to know if, since I think its the air flow that is now altered, could the gases also be not flowing as freely in the air but settling between the houses. Our door, 2 bedroom windows and back porch are all on this side.
Find an InterNACHI certified Indiana Home Inspector (and anywhere else in North America)
Old 6/10/09, 12:41 PM
Default Re: mitigation system in pennsylvania
Radon mitigation systems are installed on townhomes too, which are closer together than your house and his. I would be more concerned about whether you have radon in your home than I would be about his system venting fifteen feet from your house.
Abraham Lincoln
Old 6/10/09, 12:50 PM
Michael Larson's Avatar
Consider a muffler.
Mufflers currently offered for sale.
RadonSupplies has a 1 inch fiberglass lined muffler inside a 6 inch PVC S&D pipe. This muffler provided the least airflow resistance and the greatest DB reduction.
RadonAway offers a 4" PVC pipe lined with 1/2" foam. This muffler has the second greatest flow restriction but provides second best noise reduction.
The RCI baffled muffler is a 5" PVC pipe lined with 1/4" foam. This muffler had the greatest flow restriction and the same noise reduction as the straight through RCI muffler
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 6/12/09, 10:32 AM
Unregistered
Guest
Posts: n/a
I didn't even think about it in my own house. I'll have to pull my paperwork to see if we had that done when we bought the house 7 years ago. If it wasn't tested then, can I still do a short-term test during the summer? I read that all windows and outside doors must be closed at least 12 hours before and during testing. We have no air conditioning so our windows and doors are always open.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274
