AskNACHI.org » Moisture Reading on Ceramic Tile Shower Floor
Old 8/2/11, 4:43 PM
Unregistered
Guest
Posts: n/a
Default Moisture Reading on Ceramic Tile Shower Floor
Hello,
When my home inspector performed a home inspection, he used a moisture meter to detect moisture around the walls of the shower, but I have not seen him using the moister meter to check the ceramic tile floor of the shower.
Recently another home inspection was done and the inspector used a moisture meter to check the ceramic tile floors. Moisture was detected by the meter. I suspect some area of the grout may be moist and requires re-grouting and application of grout sealant. Visually, the shower floor has no sign of mildew or water damage. There has been no complaints from previous occupants including myself.
My questions are:
(1) What is the standard practice for home inspectors when inspecting the shower floor? Can they use moisture meter to check shower floor?
Another inspector says that he usually do not use moisture meter on the shower floor unless there is visual signs of moisture problem.
(2) If moisture meter can be used on shower ceramic tile floor, what type of moister meter should be used?
(3) (if you can help me further) what are the proper repair processes to address the moisture issue?
Thank you in advance for your help.
Regards,
Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/5/11, 8:28 AM
Charley L. Bottger's Avatar
Default Re: Moisture Reading on Ceramic Tile Shower Floor
Shower stalls are somewhat touchy to inspect for leakage if the ceramics are not visually broken. A moisture meter is of little use if the home is occupied and the shower stall was used just hours before the inspection. The grout will retain enough moisture to read high on the moisture meter. I personally prefer to use thermal imaging for shower pan leak detection
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 8/5/11, 8:33 AM
Linas Dapkus's Avatar
Linas Dapkus Linas Dapkus is offline
The standard practice to inspect a shower is a visual inspection only. If any instruments are used to detect moisture, the inspector is going beyond the Standards of Practice. However, most inspectors have moisture meters to inspect suspect areas.
Old 8/5/11, 8:37 AM
Joe Funderburk, CMI's Avatar
Many older homes used wire mesh in the concrete substrate. A moisture meter acts like a metal detector also. Other than destructive testing, observation for visible leaks is the only way to check a shower stall. I flood a shower with 2" of water and look for leaks around (and below) the shower.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
