AskNACHI.org » natural gas requirements
Old 12/5/10, 5:41 PM
rcoupel
Guest
Posts: n/a
Default natural gas requirements
I have all gas appliances in my residence including a gas fireplace. I want to add a generac 17kw natural gas generator and a 400,000 btu natural gas pool heater. I got an estimate from two local plumbers to install the gas lines. One plumber quoted $600.00 to connect both generator and pool pump to the existing meter while the second plumber says that he would need to convert the meter to high pressure, and add three new regulators otherwise nothing is going to work properly and may result in damage to the generator motor by making it run lean if anything such as the residential water heater, stove etc. is used in conjunction with the generator or if the pool heater is in use when the generator runs its weekily test. The second plumber wants to charge $3500.00. which one is doing it correctly?
Need a home inspection in Alaska? Check out InterNACHI's listing of Alaska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/5/10, 6:05 PM
Stephen W. Stanczyk's Avatar
Default Re: natural gas requirements
The second plumber is correct. The gas meter and lines must be able to provide adequate gas so that all appliances can be run simultaneously. I doubt very much if the local jurisdiction would allow the first application and was probably going to be installed without the proper permits.
Stephen Stanczyk
Old 12/5/10, 6:34 PM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is offline
To make a comment without fully evalauting what is presently there and then commenting on it would not be fair to you or either plumber. Consider calling in a 3rd and 4th if the estimates are free and see what they say. If all else fails call the gas company and get their input. Maybe they can be of assistance. Or the local build code department.
Sorry wish I could be more help, but without knowing the EXACT situation, I prefer not to comment and would tell you to seek other professionals in your area for further guideance.
Comprehensive Building Consultants
Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection.
Donate here:
or send checks to the
Fl Home and Insurance Inspector Chapter
1103 W Hibiscus Blvd Ste 311
Melbourne, Fl 32901
Old 12/5/10, 8:42 PM
Joe Funderburk, CMI's Avatar
[QUOTE=rcoupel;718034]I have all gas appliances in my residence including a gas fireplace. I want to add a generac 17kw natural gas generator and a 400,000 btu natural gas pool heater. I got an estimate from two local plumbers to install the gas lines. One plumber quoted $600.00 to connect both generator and pool pump to the existing meter while the second plumber says that he would need to convert the meter to high pressure, and add three new regulators otherwise nothing is going to work properly and may result in damage to the generator motor by making it run lean if anything such as the residential water heater, stove etc. is used in conjunction with the generator or if the pool heater is in use when the generator runs its weekily test. The second plumber wants to charge $3500.00. which one is doing it correctly?[/QUOTE]
The first thing to do is to make sure that contractor bidding on the job is a properly licensed HVAC contractor. (I would not hire a plumber.) 2nd, note that some or all of the supply piping may have to be enlarged based on where the 400K heater is being added (at the end of the longest branch or on a branch close to the meter). Have each contractor show you that they've done the proper calculations using TABLE G2413.4(1) through TABLE G2413.4(8). (That's if the IRC is the appropriate code there.) The IRC code below states one method of calculating the pipe size (you have to use the tables).
G2413.4.1 (402.4.1) Longest length method. The pipe
size of each section of gas piping shall be determined using
the longest length of piping from the point of delivery to the
most remote outlet and the load of the section.
It's impossible for us to know about the regulators or meter without more info on your pressure and the demands of each appliance in the system.
Finally, you may want to get a 3rd estimate to see which one of the two is way out in left field. Personally, I would want to understand exactly why they are doing what they say and upon what the decision is based (make them show you the math).
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
