I'm having a problem keeping the ridge cap on my roof. I live in Tennessee & we seem to have more & more high wind storms. The roof is less than 2 years old & the architectural shingles are doing fine, but the winds are tearing off shingles & sometimes the ridge cap & all.
I've look on the net & I think I need a metal ridge cap that does not need to be shingled over, but I'm having problems finding info on them. I figured since you guys inspect roofs - you might be able to give me some pointers. Thanks in advance! |
| Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
In the fine print of most shingle manufacturers warranties and/or installation instructions, you'll find that in high wind area's, they reccommend that the shingles and capping be double nailed and caulked with roofing tar. I do this on every roof I install and have yet to have any cap or shingles blow off.
As for metal ridge cap, try your local Building centre, or Home Depot, or Lowes if they're near your area. Brian Jones, 226-662-0152 mcbridesown@hotmail.com To all newcomers, "Ceade Mille Failte" (Gaelic for "A Hundred Thousand Welcomes") Last edited by bjones5; 7/1/11 at 11:47 PM.. Reason: Addinc commentary |
[QUOTE=unregistered;798299]I'm having a problem keeping the ridge cap on my roof. I live in Tennessee & we seem to have more & more high wind storms. The roof is less than 2 years old & the architectural shingles are doing fine, but the winds are tearing off shingles & sometimes the ridge cap & all.
I've look on the net & I think I need a metal ridge cap that does not need to be shingled over, but I'm having problems finding info on them. I figured since you guys inspect roofs - you might be able to give me some pointers. Thanks in advance![/QUOTE] Always go with the recommendation of the shingle manufacturer. They will include recommendations for cap shingles in high-wind areas. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
When I did mine, the instructions said to use 2 inch nails, and adhesive, where high wind conditions exist.
