AskNACHI.org » Need Arcoair Mdl No. (posted by Fred Svader)
Old 4/17/08, 12:38 PM
AskNACHI.org AskNACHI.org is offline
Automated messenger from AskNACHI.org
Please Note: AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Need Arcoair Mdl No. (posted by Fred Svader)
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]Fred Svader[/B] (from Youngstown, oh 44509). [/ASKNACHI]Subj: Re: MY FURNACE AND AIR CONDITIONER
Date: 4/17/2008 11:27:28 AM Eastern Standard Time
To: SWAZY@aol.com
Sent from the Internet (Details)
Copy and ask at www.asknachi.org
Nick Gromicko
Founder, International Association of Certified Home Inspectors www.nachi.org
Founder, Master Inspector Certification Board, www.certifiedmasterinspector.org
Executive Director, International Association of Certified Indoor Air Consultants, www.iac2.org
Host, NACHI TV, www.nachi.tv
----- Original Message -----
To: undisclosed-recipients:
Sent: Thursday, April 17, 2008 9:24 AM
Subject: MY FURNACE AND AIR CONDITIONER
To: Nachi?
I NEED TO KNOW THE MODEL No. OF MY AIR CONDITIONER.
IT WAS INSTALLED JULY 1990, GOT IT FROM MAZZA HEATING AND AIR CONDITIONING.
IT'S 1 1/2 TON UNIT,
On a sheet which I believe came with the Air Conditioning unit;
The following is on top of the sheet
PARTS REPLACEMENT GUIDE
AIR COOLED STANDARD EFFICIENCY
SPLIT SYSTEM 1 1/2 THRU 3 1/2 TON
FOLLOWING IS ON THE BOTTOM on the same side OF THE SHEET
7701-074 REVISED: OCTOBER, 1988
SUPERSEDES: DECEMBER, 1986
On the other side it shows;
I BELIEVE OR HOPE THIS ONE IS MINE??
208/230,
DESCRIPTION, Mfg name, Mfg Mdl No, 1 -1/2 TON
compressor (w/o HTR) BRISTOL H20B153ABC 0024345414 means?
The 1-1/2 Ton unit appears to be the only model H20B153ABC made for that size?
I'm getting my unit ready for the summer and noticed the model number is no where
to be found. Should it be on the removable bottom panel, the larger one. If so it's not there, or I'm unable to read it.
The following information came from the original motor AND where can I purchase it or an EQUAL TO motor to match what I need to replace it?
EMERSON MDL K55HXMMB-4296
HP- 1/10; VOLTS 220/230; Hz 60;
PH 1; RPM 825; AMP 1.0;
RPM 825; THEMALLY PROTECTED;
PART No. 343295 not sure of the last two numbers.
MFG. #K892; INS;CLASS b 40degres Cent.
AIR OVER FRAME 48Y
S/A LR4 7513 5.0 370 VAC
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274
