AskNACHI.org » Need URGENT help with question regarding fixing electrical panel in home
Old 10/3/12, 1:06 PM
Unregistered
Guest
Posts: n/a
Default Need URGENT help with question regarding fixing electrical panel in home
We are negotiating with seller on a property, and the biggest issue that came up during home inspection was the electrical panel. I need some advice on how to proceed with this issue, and how to get the seller to fix it for us.
Here are the home specs:
Style - single family home
Sqft. - 2500
Basement - 900 sqft. (partial)
Issue: 60 amp panel, with double tapped circuit breakers to bring 100 amps into the home.
The home has a Zinsco electrical panel. And the home inspector pointed out that it had reached it's capacity, and this was a safety issue concerning the double tapped circuit breakers and recommended a replacement of the panel. He quoted a low end estimate of around $4000.
So we had requested the seller to look into this issue, and upgrade to 200 amps while they are replacing the panel. Seller called their own electrician to review. And the electrician is saying that it is a 100 amp panel. And that he would "fix some of the breakers" to get it to par. And that 100 amp service is enough for a 2500 sqft. home. So now the seller is reluctant to replace the panel and upgrade to 200 amps.
Our real estate agent (who is a family friend) has used the same electrician in her home, so she recommends I should call and speak to the electrician myself to find out about the issue and his recommendations.
History about existing renters in the home: They use 10+yr old appliances in the home. And during home inspection, when the dish washer would change cycles the lights would flicker in the entire house. Clearly, 100 amp service is not enough. And when we move in we will have newer appliances (all electric powered, not gas) and plan to have larger TV's, and a home theater in the basement and possibly a back up generator.
Questions for all electricians and people with experience in this area:
Is 100 amp service really enough to power our stuff in this home?
What is ideal for this type of home?
Would "fixing the breakers" really resolve the problem?
The seller has been very stubborn through out our negotiations in fixing any health and safety issues. Is there anything I can say to the seller that would change her mind about fixing the home?
If you guys have any info please let me know. I have until tomorrow to respond to respond to the seller.
Thanks!
Need a home inspection in California? Check out InterNACHI's listing of California certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/3/12, 7:29 PM
Roy D. Cooke, Sr's Avatar
Default Re: Need URGENT help with question regarding fixing electrical panel in home
You are the purchaser . It is up to you to except the home or reject it .
You can try and negotiate for what you feel is fair .
The owner can say sorry this is the way it is.
Sorry I can not make a decision for you
Roycooke@hotmail.com I prefer E-mail
Roy Cooke UE
mlarson is on my ignore list
"All that is necessary for the triumph of evil is that good men do nothing"-----
- -Edmund Burk
Old 10/3/12, 8:01 PM
I would get another opinion from 2 or more Qualified and Reputable electrical contractors.
Christopher Currins
Professional Home Inspections In Edwardsville, Glen Carbon, Fairview Heights, O'Fallon, Godfrey, and surrounding areas of Southern Illinois
We Make It Safer
Old 10/3/12, 9:13 PM
Gilles Larin's Avatar
Gilles Larin Gilles Larin is offline
You do need an independent opinion or two here, the only way to go...
G
Gilles R. Larin,
www.inspectapro.net
Certified Master Inspector
National Home Inspector Certification #378;
Member: ANIEB; ASHI; InterNACHI; PHPIC
IAC2 Certified #IAC2-00-9310
Certified Thermographer Level II
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318
