AskNACHI.org » Noise transmission--shared-wall townhouses
Old 1/6/12, 10:22 AM
Pigghoof
Guest
Posts: n/a
Default Noise transmission--shared-wall townhouses
I moved into a townhome in 2011 and my shared-wall neighbors are extremely noisy (the police have been here numerous times regarding noise). My builder sent the results to me of the noise transmission building code test, and the structure exceeds minimum requirements. The walls do seem exceptionally thin, however, as besides loud music I can hear people talking through the walls. Do you think it is worth it to have a second test performed, and if yes, do you know who can do this?
Thanks
Need a home inspection in Oregon? Check out InterNACHI's listing of Oregon certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/6/12, 1:50 PM
Billy Boerner's Avatar
Billy Boerner Billy Boerner is offline
Send a message via Yahoo to bboerner
Default Re: Noise transmission--shared-wall townhouses
[QUOTE=Pigghoof;859669]I moved into a townhome in 2011 and my shared-wall neighbors are extremely noisy (the police have been here numerous times regarding noise). My builder sent the results to me of the noise transmission building code test, and the structure exceeds minimum requirements. The walls do seem exceptionally thin, however, as besides loud music I can hear people talking through the walls. Do you think it is worth it to have a second test performed, and if yes, do you know who can do this?
Thanks[/QUOTE]
You need to tear down the existing wall and install sound proof material behind new sheetrock. Why test if you can hear the person talking then it needs fixed.
Bill Boerner
STL Home Inspection Services LLC
Serving St. Louis/Surrounding
(314) 805-2137
office@stlhomeinspector.com
http://www.stlhomeinspector.com
Residential, Commercial, Radon, Termite, Lateral Sewer Scopes
Old 1/6/12, 4:12 PM
Sean Fogarty's Avatar
Or you could just cover your walls with sound board and an additional layer of drywall. Less messy that way.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 1/7/12, 9:33 AM
Recommended Isolation Level
An assembly rated at STC 50 will satisfy the building code requirement, however, residents could still be subject to awareness, if not understanding, of loud speech. It is typically argued that luxury accommodations require a more stringent design goal (as much as 10dB better – STC 60). Regardless of what STC is selected, all air-gaps and penetrations must be carefully controlled and sealed. Even a small air-gap can degrade the isolation integrity of an assembly.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
