AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]clarence kluesner[/B] (from bloomington wis). [/ASKNACHI]what is considerd non weight bearing wall
One that can be taken out and not affect the load bearing of the building.
The non-weight bearing walls, typically, run parallel to the floor and roof framing but not always. Consult your friendly qualified framing contractor.;-) InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Non bearing wall are the ones not keeping the second floor or roof in it's place. You can not tell just by looking at the wall, it must be properly looked over by a qualified contractor that understands structure As Larry says "Consult your friendly qualified framing contractor.:wink:"
ASNT Certified Level II Thermographer Certified Mold Inspector (Pro-Lab) Certified Mold Inspector IAC2 Certified Home Inspector INACHI 07040201 Commercial Property Inspection Certified Master Home Inspector 2008 InterNACHI member of the year Magnum Property Inspection Inspect it before you buy it 613 561 5327 office 613 929 9919 mobile We use and recommend Home Inspector Pro Software HomeGauge Software |
Or a qualified home/commercial inspector that understands and can properly identify structural members. This can usually be performed on a finished structure from the basement, crawl space, attic and with IR in some cases.
