AskNACHI.org » Oil Furnace Damper Issue (posted by J. Lawson)
Old 12/4/07, 9:53 PM
AskNACHI.org AskNACHI.org is offline
Automated messenger from AskNACHI.org
Please Note: AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Oil Furnace Damper Issue (posted by J. Lawson)
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]J. Lawson[/B] (from Seaford, VA). [/ASKNACHI]I saw your questions on line and figured I would contact you for a possible answer. I have an oil fired furnace that is about 3yrs old. When it was installed the barometric damper was installed but no weight was put on it, that I figure is utilized to control it. I am having a problem with the opening for the damper that is in the garage spitting oil soot out of it and into my garage getting on whatever I have around the damper or below it. Why is it blowing soot from the damper hole and how do I get it to stop blowing the soot out of the damper area and into my garage? I was a certified chimney sweep for about 12 years so I understand somethings but I have no experience with the barometric dapmers.
Thanks
Kelly
kozmo691@verizon.net
Old 12/5/07, 12:34 PM
David A. Andersen's Avatar
Default Re: Oil Furnace Damper Issue (posted by J. Lawson)
Please call an oil furnace tech.
Oil furnaces are very finicky and a lot of things could be the issue or associated.
We can not make evaluation on line and a box full of test equipment is required by you to further evaluate our questions.
I can tell you one thing for sure, there is something wrong.
Improper ignition. Back drafting flue.
If soot is blowing out, so is combustion gas and CO.
Why is there so much soot in the first place? Improper burn. Improper sized nozzle. Bad air mix. Bad oil pump.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274
