I encountered an outdoor electric panel and wondered if this is allowed by code. It is exposed to the weather and has a missing breaker or slot cover.
| Need a home inspection in North Carolina? Check out InterNACHI's listing of North Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Here in AZ, exterior mounted panels are the norm and not the exception.
An unfilled opening in the deadfront is worthy of a write up |
Being that you're a home inspector:
http://asp.homecheck.com/search/type_detail.asp?id=22419 you should no we don't inspect to code. Also that any opening (missing breaker or slot cover) in a service panel is a safety hazard. If you don't I feel for your past clients. Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
I don't know about code but I do know that there are service panels that are designed for the exterior. Usually there is a meter attached to them here. The door often covers the whole front. If your a Home Inspector join NACHI.
If you have an exterior panel enclosure (NEC Article 312) it is required in accordance with Section 110.28; this section defines the type of NEMA rating that must be used on exterior rated panel enclosures.
Paul W. Abernathy |
