AskNACHI.org » Owner
Old 5/29/10, 8:49 AM
ron pronchuk
Guest
Posts: n/a
Default Owner
I live in an northern Ontario and question is in reference to insulation. The top 4 ft portion of an 8ft concrete basement wall has been wood framed and filled with fiberglass bat insulation. The lower portion of the concrete wall is bare.
There appears to be mold covering most of the insulation and signs of staining running down the walls from where the insulated portion is present.
Behind the insulation is what appears to be tar paper which is against the concrete wall. The moisture content is also quite high.
So what we have is open to air fiberglass insulation which is on top of tarpaper which is against the concrete wall. Most of the insulation has turned some form of dark discoloration.
Need a home inspection in Vermont? Check out InterNACHI's listing of Vermont certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/29/10, 4:23 PM
Roy D. Cooke, Sr's Avatar
Default Re: Owner
Need more information
What is the floor .
Is the basement vented to the outside.
What is the outside temp.
What is the outside Humidity.
Is there and running water in Basement .
Do you have a sump pump and if so how often does it come on .
Do you have a humidifier in the basement and is it running .
What is the humidity of the basement .
Do you have a dehumidifier in the basement and is it running.
These are just a few question that need to be answered ,to try and help your concerns .
Do you have a clothes dry and is it vented to the outside .
Does any one hang damp clothes to dry in the basement.
Do you store fire wood in the basement .
Do you have a cistern in the basement and is there water in it.
Roy Cooke
Old 5/29/10, 6:45 PM
James H. Bushart's Avatar
Default Re: Owner
Air movement can discolor fiberglass insulation. Discoloring or darkening is not, by itself, an exact indication of mold.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
