We are looking at a house with a "dry" finished basement, finished by the owner. In framing the walls, he did not use pressure-treated wood where it contacts the concrete floor. Is this a problem?
| Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It is preferred but if it all stays dry, it will probably last longer than you.
In my area we rarely see pressure treated wood for the sills, but we do recommend plastic or better yet; sill gasket, which is a closed cell foam strip that is sandwiched between the bottom sill plate and the concrete floor.
In my area PTL is required when ever the wood comes in direct contact with concrete.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
It is not required in Oregon But a good Idea. Or the Seal sealer or vapor barrier.
House 2 Home LLC 503-602-1420 HomePros@House2HomeLLC.ORG Protecting Peace of Mind One House at a Time IAC2 Certified IR Certified A favorite place on Google Maps |
[QUOTE=mlarson;610262]In my area PTL is required when ever the wood comes in direct contact with concrete.[/QUOTE]
Ditto. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
gmoore7 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Not required in Ontario. However, as stated it is good practice to have a gasket or plastic barrier.
PTL is required in florida.
Kenneth Townsend, CPI Gulf Coast Inspections Professional Inspections and Consulting Bradenton, Florida 941-779-4400 Serving the beautiful West coast of Florida "Guard Against the Impostures of Pretended Patriotism" George Washington, 1796
Put a box on the floor and come back in a couple of days and see if it's wet underneath. Take a moisture measurement prior and after.
It is highly likely that proper vapor retardants were not use below the concrete during initial construction because the basement was not intended to be finished. Concrete does not stop water/water vapor intrusion. Does it really matter if there is a code requirements for this type of thing? How about doing some testing to determine if it's necessary and adapt your construction accordingly? "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
[QUOTE=gmoore7;610442]Not required in Ontario. However, as stated it is good practice to have a gasket or plastic barrier.[/QUOTE]
Gerald, Are you sure about that? OBC 9.23.2.3 Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
