AskNACHI.org » Proper Drain Venting??? Please HELP! (posted by Mary)
Old 3/14/08, 1:25 PM
AskNACHI.org AskNACHI.org is offline
Automated messenger from AskNACHI.org
Please Note: AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Proper Drain Venting??? Please HELP! (posted by Mary)
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]Mary[/B] (from St. Louis, MO 63139). [/ASKNACHI]We recently got a home inspection and the report came back saying... "improper drain vent connection below floor and trap crown at kitchen sink drain - repair needed at this time, vent connection must occur at or above trap crown." - Then, the "Un-vented "S" trap needs to be vented at Kitchen sink drain" box is checked.
What does this mean? We need to buy a vent connection and install?
Old 3/14/08, 2:25 PM
Christopher Currins's Avatar
Default Re: Proper Drain Venting??? Please HELP! (posted by Mary)
You should call the person that did the inspection and have them explain it to you. Apparently the trap is not vented properly which can cause the water in the trap to drain and permit sewer gases to vent through the drain and into the kitchen.
Christopher Currins
Certified, Licensed
Old 3/14/08, 10:23 PM
Bruce A. King's Avatar
Here's a link to a picture of a p-trap and air admittance valve.
These valves are used when it is not easy to vent through the main pipe through the roof.
[url]http://www.rd.com/images/tfhimport/2003/20031001_Ask_Handyman_page002img001_size2.jpg[/url]
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
