AskNACHI.org » Radon
Old 11/10/09, 6:34 PM
Randal L. Benson Randal L. Benson is offline
Default Radon
I did a radon test that scored 18, but the cannister pick up date and time was not marked, the buyer picked it up for me and mailed it in; without marking the time and day. So I did another radon test and this time the seller removed the bucket the cannister was setting on. My question is: Will this radon test be useable or accurate?
Find an InterNACHI certified Vermont Home Inspector (and anywhere else in North America)
Old 11/10/09, 6:47 PM
mnahrgang's Avatar
Default Re: Radon
Nope. But if you informed the seller that the canister could not be moved, in this case, you could recommend that he pay for the third test.
Mistake 1: using canisters in stead of a CRM
Mistake 2: allowing the buyer to pick-up canisters.
Mistake 3: not educating seller of proper protocols (possibly)
Mark Nahrgang
www.HeyMark.info
Old 11/10/09, 8:02 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
Default Re: Radon
Absolutely correct Mark. Why would you be having the customer picking this stuff up for you in the first place, isn't that your job as the inspector?
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 11/10/09, 8:04 PM
mnahrgang's Avatar
Default Re: Radon
Only time I have ever done that was when the test was being done for the home owner themselves, and it wasn't in regards to a RE transaction.
Mark Nahrgang
www.HeyMark.info
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274
