AskNACHI.org » Radon inspection (posted by Tom Irwin)
Old 9/4/08, 10:29 AM
AskNACHI.org AskNACHI.org is offline
Automated messenger from AskNACHI.org
Please Note: AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Radon inspection (posted by Tom Irwin)
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]Tom Irwin[/B] (from Albany, NY). [/ASKNACHI]
I am not certified as a radon expert.
But, do I need special training to take samples of radon to a lab and explain the results to the client?
Old 9/4/08, 10:31 AM
Michael Larson's Avatar
Default Re: Radon inspection (posted by Tom Irwin)
Many states regulate Radon testing and mitigation.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 9/4/08, 10:50 AM
mnahrgang's Avatar
[quote=mlarson]Many states regulate Radon testing and mitigation.[/quote]
Exactly. I'll also add that for those states that do not regulate it, you should be well trained anyway. An incorrectly performed test, may lead to inaccurate readings. At best it may cause the expense of an unnecessary mitigation to be performed by the property owners. At worst, it could cause the owners to live in a excessively high level of radon without knowing it.
An ethical inspector WANTS to know what he or she is doing, even if its not required by law.
Mark Nahrgang
www.HeyMark.info
Old 9/4/08, 10:51 AM
New York requires Radon measurement firms to report results to state.
[URL="http://www.health.state.ny.us/environmental/radiological/radon/radonlaw.htm"]http://www.health.state.ny.us/environmental/radiological/radon/radonlaw.htm[/URL]
Michael Larson
Hudson, WI
InspectraPro
and
Old 9/19/08, 10:02 AM
Rick K. Kie's Avatar
Rick K. Kie Rick K. Kie is offline
In NYS you can use a charcoal testing device Like air-check for this [URL="http://www.radon.com/"]http://www.RADON.COM[/URL] follow all the instructions to a tee and the lab has to report the data to the state, you don't need to.
Although in NYS you need to be ELAP certified to use a CRM.
Rick Kie
Old 11/7/08, 12:29 PM
tirwin tirwin is offline
Thank you for your response. I used the charcoal canisters.
Tom Irwin
Old 11/7/08, 12:34 PM
David P. Valley's Avatar
[quote=tirwin;435763]Thank you for your response. I used the charcoal canisters.
Tom Irwin[/quote]
Tom,
I use charcoal canisters also. No special license or training is required for this type of radon testing in Massachusetts, but it's best to be trained in the proper placement of the canisters and it's good to know the basics regarding Radon, due to the questions that'll be asked during your inspections. If you're placing radon canisters, please check with your local radon laws and if there aren't any, school yourself in Radon testing, it's hazards and how it occurs.
Old 11/8/08, 11:50 PM
pwiseman pwiseman is offline
There is a great website for you and your clients. [URL="http://www.epa.gov"]www.epa.gov[/URL]
Just about anything you want to know about Radon. Did you get the canisters from RTC (Radon Testing Corp.) in Elmsford, NY? If so they offer classes that comply with all regulations.
Good Luck
Patrick
Patrick Wiseman
PJC Home Inspections LLC
Washingtonville, New York
InterNACHI 107051007
http://www.wisemanhomeinspections.com
Performing Home Inspections in Newburgh, Monroe, Middletown, Goshen, New York
Old 11/26/08, 7:55 AM
James White James White is offline
I am taking a certification course at: [URL="http://www.rtca.com/training.asp"][COLOR=#810081]http://www.rtca.com/training.asp[/COLOR][/URL]
Maybe they have a location near you. check them out.
Old 12/26/08, 5:26 PM
Joseph Tribuzio's Avatar
Joseph Tribuzio Joseph Tribuzio is offline
[quote=AskNACHI.org;407627][asknachi]This question was posted on [I]AskNACHI.org[/I] by [B]Tom Irwin[/B] (from Albany, NY). [/asknachi]
But, do I need special training to take samples of radon to a lab and explain the results to the client?[/quote]
You have to understand how RADON works , how it can be effectively measured to get the best results. Otherwise you could be wasting time.
I only use continuous radon monitors.
Joseph Tribuzio 708 453 8447
Tribuzio Home Inspection Services
CHICAGOLAND, ILLINOIS
www.thishomeinspector.com
ID# NACHI07062507
IL Lic#450.003128
Radon lic# RNIT2008216
Home Inspector Pro Software
HIP Web Hosting
Old 1/17/09, 9:25 AM
Tom, I wanted you to know that any firm that you choose to send your charchoal canister too has to be a NYS ELAP certified radon lab.
Rick Kie
Old 1/22/09, 2:53 PM
Tim Spargo's Avatar
[url]http://nrsb.org/State%20Cert%20Programs.htm[/url]
Has a list of who has a program or not..
The home page has a list of state radon offices as well.
Testing is more of a service to sell with an inspection..
If you don't have Continuous Monitor w/tamper indication.. (I get nervous on vacants anyway) I would recommend a sump pit similar to what Nick (search on site)had shown with the sand and ball inside (you can see if they moved it around and note on report and/or to lab) as Real Estate testing leaves lots of room for "adverse conditions".
Tell the seller that if they leave the windows open and a breeze blows thru it will increase the results... there's a lil truth to that too. Keep closed conditions 12 hours prior if using samples etc. There is some evidence that air moving [I]across [/I]sample may increase results..
Tim
Tim Spargo
Spec Rite Inspections
661-317-5770
Old 1/23/09, 2:59 PM
[quote=tspargo;476137][URL]http://nrsb.org/State%20Cert%20Programs.htm[/URL]
Tim[/quote]
Agreed!
ID# NACHI07062507
IL Lic#450.003128
HIP Web Hosting
Old 1/25/09, 4:02 PM
Frank P. Macak Frank P. Macak is offline
Hi Rick, this is Frank Macak, I met you at the Upstate School of Training. I am just getting into the business and just want to say HI to all of you. I do have a question regarding the cannisters. I understand that there are 2 sizes 4" and 2" cannisters. I also understand that you need to use the 4" canisters. Do you know of any sources in the NYState ? Some guys were suggesting Accustar PA lab, but they are not licenced for NY, but the Accustar lab in MA is. Thanks
Frank
Old 1/25/09, 4:41 PM
David A. Andersen's Avatar
Do you want to get involved in something that may cost $$$$ for buyers and sellers alike? Then have it come back on you that your testing was not in accordance with protocol.
There are standards for testing set by the EPA, but in the real world of Real Estate in Nashville, TN. you get one high test and it is fix it time! No re-testing. No averaging of tests, no nothing. High test, fixing it now is less than dragging things on and loosing a sale.
Someone goes through this and THEN finds that you didn't follow protocol.....
Just my perception on any ancillary service...
BPI# 5015804
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274
