AskNACHI.org » radon system loud
Old 11/18/09, 9:56 AM
Unregistered
Guest
Posts: n/a
Default radon system loud
When we had our old addition rebuilt a few months ago, our mitigation system was turned off so we weren't working in exiting fumes. The new addition's roof is now higher than the old one so the exhaust pipe is now about 6 inches below the roof line. The code inspector said the pipe should be extended above the roof line but in the meantime the system is now making a loud humming noise that we can hear when we are outside or our windows are open. We think there is something wrong with the fan and called the installer. It was installed about 12 years ago. The installer says that we need a new fan because the system was turned off when our addition was being built, that we are not supposed to turn it off. Without looking at it, he says it will cost me $3000.00 to fix it. Is this correct? I thought I should have someone look at it before I commit and while they are here, have them adjust the exhaust so that it exits above the roof line. Or could the problem just be the exhaust venting below my roof?
Find an InterNACHI certified Missouri Home Inspector (and anywhere else in North America)
Old 11/18/09, 8:25 PM
Nick Gromicko's Avatar
Default Re: radon system loud
Google "radon system exhaust mufflers." There are about 4 or 5 different manufacturers. You can make one pretty easily for about $25 too. If the noise is coming from vibration against your home rather then air exhaust, try cutting the pvc pipe on both sides of the fan and isolating the fan between a couple rubber boots with hose clamps. Cost $10.
Find a Home Inspector
Old 11/18/09, 8:48 PM
mnahrgang's Avatar
$3000 for a fan? I think there is a misunderstanding somewhere. An entire new system for a large home would be less than $1500 in most cases, probably less. Call another mitigation company...
Mark Nahrgang
www.HeyMark.info
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274
