Hello,
Can you tell me if a Trane model number SXHCC7540, SXHCC2540, SXHCC2040, and so on in this line are heat pumps? How do they heat when they go from Air conditioning to heating? Do they use 40% more amps like a normal heat pump if there is no gas available? Thanks and God Bless You, |
| Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Since no one has chimed in I'll try to help......
1. Your questions are not detailed enough. 2. Are you talking about a dual fuel unit that uses gas when the outside temp is below a certain point? 3. When a regular heat pump gets behind on the heating it will turn on electric strips (or gas if that is the type you have). The electric strips can be 5kw and up (if installed). When these are on the total current draw will be 2 to 5 times higher than what the heat pump compressor normally uses. They can be used with the compressor turned off if it is bad or iced over due to an ice storm by selecting "emerg" or "aux heat" mode at the thermostat. The questions about particular model numbers will have to be directed to a Trane dealer. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Bruce,
Thanks a lot for helping me. Heres the thing, there is no gas at all there is only electric. I am going to test the motors for efficiency. Power Factor and if they are heat pumps then they will use 40% more amperage usually. I want to know if these models are those type of units? Heat pumps are not. I have been told there are a linear and non-linear load type units out there. Please help Bruce. God Bless You, Brett Davis |
The only info I can find on that first model number indicates it is an air conditioner.
You need to call a Trane dealer for info. Here is some info about linear heat pumps from 1984 http://www.ornl.gov/sci/engineering_science_technology/eere_research_reports/thermally_activated_technologies/engine_driven/ic_engines/ornl_sub_80_61619_1/ornl_sub_80_61619_1.pdf B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
