AskNACHI.org » Septic tank
Old 4/15/10, 4:19 PM
Unregistered
Guest
Posts: n/a
Default Septic tank
Where can I locate where the leach field is at on a property that has a septic tank?
Need a home inspection in Utah? Check out InterNACHI's listing of Utah certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/15/10, 6:55 PM
James E. Braun, CMI's Avatar
Default Re: Septic tank
By water witching http://www.encyclopedia.com/doc/1O13-waterwitching.html. I do it all the time.
Old 4/15/10, 7:11 PM
Nick Gromicko's Avatar
Nick Gromicko Nick Gromicko is online now
http://www.nachi.org/septic-course.htm
Find a Home Inspector
Old 4/15/10, 7:20 PM
mnahrgang's Avatar
As a home owner you probably can't because you do not have, and probably do not want to buy, the proper tools.
You can use a probe (commonly referred to as an "ugly stick") to gently probe the ground to locate the pipes. You can also dig small holes to locate the field. If you have grass planted, sometimes the grass is greener of the trenches.
Practically speaking though you aren't likely going to do it yourself.
Mark Nahrgang
www.HeyMark.info
Old 4/15/10, 9:09 PM
William C. Martin William C. Martin is offline
You may want to check with the local authority (Health, Sewer, etc. Dept) that issues septic permits. If there is permit on file it normally shows location of home, septic tank and field drain(s).
Old 4/15/10, 9:10 PM
Joe Funderburk, CMI's Avatar
Go to the county permitting dept. There should be plans that they approved showing the drain fields, tank capacity, etc. in order to get the permit to install the system.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
