AskNACHI.org » sewer smell only in the AM (posted by Buddy Moore)
Old 9/26/07, 8:39 AM
AskNACHI.org AskNACHI.org is offline
Automated messenger from AskNACHI.org
Please Note: AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default sewer smell only in the AM (posted by Buddy Moore)
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]Buddy Moore[/B] (from Murfreesboro,TN USA). [/ASKNACHI]I inspected a house that home owners said a strong oder was coming from the upstairs bedroom but only in the morning. They had their septic tank clean thining this was the problem because the smell is a sew like smell but it did not stop the oder. We did a mold test an dit came back clean. any ideas of what this smel could be from. it has been there for along time now.
Old 9/26/07, 9:24 AM
Default Re: sewer smell only in the AM (posted by Buddy Moore)
That would be the A.M. movement.:D
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 9/26/07, 9:33 AM
Michael Larson's Avatar
Buddy,
You have provided very little information that would lead to a helpful conclusion.
There are many causes of unusual odors including dead animals in the walls etc.
Perhaps it would be wise to advice the client to have the plumbing system checked by a qualified professsional to eliminate that possibility.
Old 9/26/07, 9:38 AM
Bob Elliott's Avatar
Buddy we would need some more clues.
Are there any upstairs bathrooms.?
What is the location of the waste vents.?
Have you checked for signs of backup in the drain pipes.
If you have a sink upstairs which never gets used the water in the drain trap will eventualy dry out thus allowing sewer gas to back up through the drain.
You could also have a broken pipe inside one of the walls.
Check for signs of leakage.
I hate to cop out by saying hire a plumber but some things need taking care of in person.
Old 9/26/07, 3:42 PM
Christopher Currins's Avatar
Does this smell occur only in the mornings after they do their "thing" the night before?
Christopher Currins
Certified, Licensed
Old 9/26/07, 4:00 PM
rwand1 rwand1 is offline
Try some vinegar or 3% Peroxide solution down the drains of the bathroom, kitchen, sink, shower followed by a kettle full of boiling water. You could be smelling bacteria or other matter stuck in the trap.
Old 9/26/07, 6:03 PM
Ray I used to recommend vinegar be poured down the drains periodically as it dissolves soap.
Hair clings to the soap causing blockage.
Old 9/26/07, 6:20 PM
Rob,
Vinegar and Baking Soda also works well.
Pretty tough call considering the lack of info. Perhaps further details with further info will be forth coming?
Cheers,
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
