AskNACHI.org » Shower fan and lights
Old 11/18/09, 9:32 PM
Unregistered
Guest
Posts: n/a
Default Shower fan and lights
Would like to know if puting a fan and light combination above a bath tub with gfi protection is aloud by code and if so does it have to be 8 feet above the tub or can it be lower like 7 foot
thank you don
Old 12/14/09, 6:52 PM
William J. Decker's Avatar
Default Re: Shower fan and lights
[QUOTE=Unregistered;584864]Would like to know if puting a fan and light combination above a bath tub with gfi protection is aloud by code and if so does it have to be 8 feet above the tub or can it be lower like 7 foot
thank you don[/QUOTE]
When you say "code", I asume that you are referring to the local building codes, in your area.
Home inspectors do not comment on local codes because they very so much from area to area.
That being said, the current national codes and construction standards do not allow ceiling fan and light combinations (I assume you are referring to a regular ceiling type fan) above bathtubs or in shower enclosures. There are specailly designs recessed lights (like can lights) that are allowed for use in these areas, but they are sealed and have special gaskets to keep water out.
Hope this helps;
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
