AskNACHI.org » sliding windows leaking when they get wet
Old 5/5/11, 2:00 PM
Unregistered
Guest
Posts: n/a
Default sliding windows leaking when they get wet
I have a brand new "custom" home in El Paso. While washing the windows on the outside, water started to leak into the room. Realtor says this is normal but im not buyin it. Anyone have any expertise. They are sliding windows.
Need a home inspection in South Carolina? Check out InterNACHI's listing of South Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/5/11, 3:19 PM
James H. Bushart's Avatar
Default Re: sliding windows leaking when they get wet
[QUOTE=Unregistered;779852]I have a brand new "custom" home in El Paso. While washing the windows on the outside, water started to leak into the room. Realtor says this is normal but im not buyin it. Anyone have any expertise. They are sliding windows.[/QUOTE]
It is not normal...but real estate salesmen claiming defects to be "normal" ... well, that's normal. Not only is the window leaking water, but it is leaking air and is costing you a lot of money in wasted energy.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 5/5/11, 3:24 PM
Stephen W. Stanczyk's Avatar
Depends on where the water is coming in. If it is filling the tracks and overflowing inside the home, the drains are either clogged or were never knocked out.
Stephen Stanczyk
Old 5/5/11, 3:25 PM
Christopher Currins's Avatar
You need to bypass the realtor and contact the builder. This "normal" leak is only going to cause more damage to home.
Christopher Currins
Certified, Licensed
Old 5/6/11, 9:37 AM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is offline
Sliding windows do leak on the end because of the caps over the attachment nails. Slide your window and you will see the caps that have like crowns on them.They may have Low E coating and triple pane but this does not do a whole lot of good if air and water can get in past the panes of glass. The only way to solve this is to remove the little crowns and put weather proof strips on the outside seam of the window and re-adjust the locking mechanism.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 5/8/11, 8:41 PM
Jeff W. Watson Jeff W. Watson is offline
the window is probably not flashed
Old 5/18/11, 7:44 AM
Jerry Suarez's Avatar
Jerry Suarez Jerry Suarez is offline
There is no such thing as a normal leak..
Florida Licensed HI #2268 | 1-800-276-2607
Florida Home & Insurance Inspector Chapter Board Member
"When a home inspection is vital to your future investment"
Old 5/18/11, 1:27 PM
Linas Dapkus's Avatar
Linas Dapkus Linas Dapkus is offline
[QUOTE=kwood;780211]Sliding windows do leak on the end because of the caps over the attachment nails. Slide your window and you will see the caps that have like crowns on them.They may have Low E coating and triple pane but this does not do a whole lot of good if air and water can get in past the panes of glass. The only way to solve this is to remove the little crowns and put weather proof strips on the outside seam of the window and re-adjust the locking mechanism.[/QUOTE]
Why should he do anything??? It's a new home. Call the builder immediately and have him fix or replace the windows. What about mold? Is there mold growth under the floor covering or behind the walls because of the leak? Lots of possibilities.
Old 5/18/11, 2:08 PM
Joe Funderburk, CMI's Avatar
[QUOTE=jwatson;780818]the window is probably not flashed[/QUOTE]
Ditto.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 5/18/11, 5:47 PM
KEVIN WOOD's Avatar
I agree with what you are saying. The repair is to remove the window and replace with a better style. Most will not remove the window and that is when the only solution is to do what I have said.
It is always important to check if the leak has created a problem with the wall because of the sliding windows. This is a must to correct the problem.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
