AskNACHI.org » Soot from Barometric Draft Damper (posted by Ted Hull)
Old 5/10/07, 1:45 AM
AskNACHI.org AskNACHI.org is offline
Automated messenger from AskNACHI.org
Please Note: AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Soot from Barometric Draft Damper (posted by Ted Hull)
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]Ted Hull[/B] (from Baltimore, MD). [/ASKNACHI]have an older oil furnace with Barometric Draft
Damper. The last time the unit was serviced, the
igniter was adjusted to prevent the access door from
blowing open during ignition. Even so, soot still
escapes from the draft damper.
Is there a way to filter the soot that the damper
spits out? Could a filter box be attached to the
damper (on the intake side)?
Thanks,
Ted
Old 5/10/07, 6:36 AM
phinsperger's Avatar
Default Re: Soot from Barometric Draft Damper (posted by Ted Hull)
Hi Ted, Soot shoud not be coming out of the barometric damper so a filter would not be needed. You may have a blockage/restriction in the flue or damper may just need to be adjusted. There is a little thumb screw on the damper that does this. I think you need to call back your service guy and address the problem ASAP.
Old 5/10/07, 9:37 AM
jjordan jjordan is offline
Mr. Hull,
As Mr. Hinsperger states, soot should not be blowing out the draft damper. You should consider having an HVAC or Burner Technician check your system.Typically a check of the flue/chimney should be performed to ensure proper draft. The burner control adjustments should be checked, the furnace cleaned, and an efficientcy test performed. Usually older burners are not as efficient as newer ones, but, you still should not be sooting at the damper. I did a watch and learn once for GOTT Co., believe me they have a lot to learn, so check around for a reliable HVAC contractor.
You can call me if you wish at 301-274-3358 for any questions.
Regards,
John Jordan
Old 5/11/07, 6:49 AM
rwand1 rwand1 is offline
Have the furnace tech perform a draft test on the furnance to ascertain exhaust temps. If you have a long chimney run which is prone to cooling down between furnace on/off periods this could result in exhaust spillage until the chimney heats up and begins to draw.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
