AskNACHI.org » Stairs for Side Door (posted by L)
Old 5/5/08, 1:22 PM
AskNACHI.org AskNACHI.org is offline
Automated messenger from AskNACHI.org
Please Note: AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Stairs for Side Door (posted by L)
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]L[/B] (from Bridgeport, PA). [/ASKNACHI]I need new steps leading to the side entrance of my house. Currently we have a set of wooden stairs (3 or 4 steps) going from the side door down to ground level. I'm not sure how they are attached to the side of the house, but on the ground they are actually sitting on two bricks, not actually resting on the ground. They were obviously a temporary solution by the previous owners of our home. I don't even know what type of craftsman or contractor to look for to build new steps. We use this door as the primary entrance to our home, as it is next to the driveway, so the steps need to be sturdy to stand up to a lot of use. I'm also not sure what material we should look for - concrete? Or some sort of wood composite? Our front stoop is made of brick with slate on the stairs and top surface. Thanks for your recommendations.
Old 5/5/08, 1:30 PM
Bob Elliott's Avatar
Default Re: Stairs for Side Door (posted by L)
L
Here is a good stairway course you can view.
[URL="http://www.nachi.tv/episode16"]http://www.nachi.tv/episode16[/URL]
Old 5/5/08, 2:47 PM
[COLOR=blue]There is a variety of ways to provide steps on a residential entrace. [/COLOR]
[COLOR=#0000ff]The least expensive would be made out of Pressure treated lumber, or Cedar, or could be cast in place concrete like this;[/COLOR]
[IMG]http://images.meredith.com/bhg/images/08/a_1250821.gif[/IMG]
Step 1.
Step-By-Step
[IMG]http://images.meredith.com/bhg/images/08/a_1250822.gif[/IMG]
Step 2.
[IMG]http://images.meredith.com/bhg/images/08/a_1250823.gif[/IMG]
Step 3&4
[COLOR=blue]The other alternative would be precast steps, where you chose what you want and they are delivered and installed complete with rails. [/COLOR]
[FONT=Arial][COLOR=#181844][IMG]http://www.genestprecast.com/images_new/step3.jpg[/IMG][/COLOR][/FONT][I][B][FONT=Arial]Natural Steps[/FONT][/B][/I]
[FONT=Arial][COLOR=#181844][IMG]http://www.genestprecast.com/images_new/step5.jpg[/IMG][IMG]http://www.genestprecast.com/images_new/step4.jpg[/IMG][/COLOR][/FONT]
[FONT=Arial][COLOR=#181844]Functional and decorative, railings are available in aluminum and wrought iron. Aluminum is available in white or black. Wrought iron is available in black only.
[/COLOR][/FONT]
[FONT=Arial][COLOR=blue]Hope this helps. [/COLOR][/FONT]
[FONT=Arial][COLOR=#0000ff]Marcel :) :D [/COLOR][/FONT]
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
