AskNACHI.org » Styrofoam exterior coating (posted by Klaus Proehl)
Old 9/4/08, 1:56 PM
AskNACHI.org AskNACHI.org is offline
Automated messenger from AskNACHI.org
Please Note: AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Styrofoam exterior coating (posted by Klaus Proehl)
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]Klaus Proehl[/B] (from Burnsville, MN). [/ASKNACHI]I currently have 2” Styrofoam on the outside of my basement walls, it has been there a little too long. I can take care of the UV damaged areas but with what can I use to fill the holes made by woodpeckers? The second question is? What is a good covering for the foam to protect it from further degradation by UV? Is there a good trowel on or brush on product available? Maybe the question should be; is there a decent book available that covers answers to these seemingly common questions about the use of Styrofoam?
Old 9/4/08, 7:39 PM
Carl A. Brown's Avatar
Default Re: Styrofoam exterior coating (posted by Klaus Proehl)
Great stuff.
Then rasp it flat.
Cover it with EIFS mesh and basecoat and finish.
I am not saying it is to MFGRS. specs but it will protect it.
If it is where no moisture can get behind it from the top side.
Do you have a couple pictures?
Old 9/7/08, 8:34 AM
Rodney Misener's Avatar
Rodney Misener Rodney Misener is offline
Dryvit system works too.
Rodney Misener, CMI
Trinity Inspection Services
Pictou County, Nova Scotia
http://www.trinityinspectionservices.com
Certified Home Inspector
Certified Level 1 Thermographer
Certified Energy Advisor
WETT Certified Inspector
IAC2 Radon/Mold Certified
Infrared Certified
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274
