AskNACHI.org » Tankless hot water heater (posted by Joelle)
Old 12/23/07, 11:28 AM
AskNACHI.org AskNACHI.org is offline
Automated messenger from AskNACHI.org
Please Note: AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Tankless hot water heater (posted by Joelle)
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]Joelle[/B] (from Sudbury, ON). [/ASKNACHI]Looking for information on tankless hot water heater systems. Efficiency, cost/savings....
Joelle
Sudbury, ON
Old 12/23/07, 12:23 PM
Gary Oleski Gary Oleski is offline
Default Re: Tankless hot water heater (posted by Joelle)
[URL="http://www.chilipepperapp.com/tankless.htm"][COLOR=#551a8b][B]Tankless Water[/B] Heaters - The Good and the Bad[/COLOR][/URL]
Gary Oleski Home Inspections
Home Inspections Connecticut
Connecticut . 06610
NACHI04012833
CT#HOI.341
C M I
Old 12/23/07, 1:56 PM
Barry Adair's Avatar
Joelle,
Hope this helps [URL="http://www.nyletherm.com/whitepaper2.pdf"]http://www.nyletherm.com/whitepaper2.pdf[/URL] direct from a fairly large WH manufacture here in Texas.
Appears they are pretty honest about their own products, they make both.
All of the plumbers and their kids I know still own tank models, why?
[B][FONT=Utopia-Semibold][SIZE=3][LEFT]Conclusion[/LEFT]
[/SIZE][/FONT][/B][FONT=Utopia-Semibold][SIZE=3]
[/SIZE][/FONT][FONT=Utopia-Regular][SIZE=3][LEFT]Tankless water heaters have advantages. They are
compact and are easy to drain; consequently, they
could be ideal for applications where space is a
premium or in small vacation homes. In addition,
they could serve quite effectively in point of use
applications. However, their use as the central
source of hot water in a residence should be carefully
considered. While tankless water heaters offer
some modest energy cost savings over storage
water heaters, those minimal gains are at the
expense of higher initial costs, higher installation
costs, higher maintenance costs and the potential
need for lifestyle changes to accommodate the limited
flow rate output of tankless water heaters. In
addition, with the coming increase in Energy
Factor required by NECA II, the Energy Factor differences
between tankless and storage water
heaters will become even smaller.
If a customer regularly runs out of hot water
from his storage water heater, the most cost-effective
solution is the purchase of a larger, correctly
sized, high-efficiency storage water heater. For
those who want enhanced energy efficiency, the
most cost-effective solution is the purchase of a
[/LEFT]
correctly sized, high-efficiency storage water heater.
[/SIZE][/FONT]
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274
