Can I use a metal duct from my basement that is connected to the ac unit and up to the second floor as a way to get speaker, internet and telephone lines to my bedroom near my work station?
Also, is there a rule that does not alllow a wall switch for the bathroom from being installed outside before entry? I want the put a switch with a light to show when the switch is in the on position. |
| Find an InterNACHI certified Nevada Home Inspector (and anywhere else in North America) |
First I would say NO you can't use your duct for this purpose, check out 300.22(B) of the NEC and without knowing the ratings of the cables you want to use it would not be advised. I would venture to say the jackets you are using are not rated for the environment and are probably of a non-metallic jacket.
Second, the National Electrical Code says you must have a switched luminaire in the bathroom. based on the way the NEC reads it says the "lighting outlet" has to be in the bathroom but it does not define the switch location as long as it switches the lighting outlet. (1) Habitable Rooms. At least one wall switch–controlled lighting outlet shall be installed in every habitable room and bathroom. So if you would like just outside before entry I dont see a problem with it. If you are wanting a switch with a pilot light on it in the on position...go for it. Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year Last edited by pabernathy; 7/6/09 at 3:35 PM.. Reason: Brain Fart Reference Number....lol |
Paul,
can the NEC code 200.22(B) and others be found on the internet? Rich Mangold RCM Home Inspections, LLC www.RCMHomeInspections.com Email: Rich@RCMHomeInspections.com Phone: 847-698-5993 |
Actually, I think Paul meant to reference NEC 300.22 but, in any case, the 2005 version of the NEC can be viewed at http://www.nfpa.org/freecodes/free_access_document.asp?id=7005SB (with a free account) and newer versions will cost you.
lol....yeah I am not sure why I said 200.22...lol...Brain Fart. I should do more Cut and Paste and it would not happen...lol
Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
(B) Ducts or Plenums Used for Environmental Air. Only
wiring methods consisting of Type MI cable, Type MC cable employing a smooth or corrugated impervious metal sheath without an overall nonmetallic covering, electrical metallic tubing, flexible metallic tubing, intermediate metal conduit, or rigid metal conduit without an overall nonmetallic covering shall be installed in ducts or plenums specifically fabricated to transport environmental air. Flexible metal conduit shall be permitted, in lengths not to exceed 1.2 m (4 ft), to connect physically adjustable equipment and devices permitted to be in these ducts and plenum chambers. The connectors used with flexible metal conduit shall effectively close any openings in the connection. Equipment and devices shall be permitted within such ducts or plenum chambers only if necessary for their direct action upon, or sensing of, the contained air. Where equipment or devices are installed and illumination is necessary to facilitate maintenance and repair, enclosed gasketed-type luminaires shall be permitted. Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
