AskNACHI.org » testing central a/c in winter (posted by tanya marquette)
Old 12/6/07, 6:34 PM
AskNACHI.org AskNACHI.org is offline
Automated messenger from AskNACHI.org
Please Note: AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default testing central a/c in winter (posted by tanya marquette)
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]tanya marquette[/B] (from new paltz, new york). [/ASKNACHI]what is the nachi position on testing central a/c systems in winter months.
are there any special protocols to follow at this time of year.
what concerns are there for damage to the house?
Old 12/6/07, 8:22 PM
apolillo's Avatar
apolillo apolillo is offline
Please Note: apolillo is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: testing central a/c in winter (posted by tanya marquette)
I do not check AC systems when the exterior temp is below 65. It may cause damage to the unit due to lack of lubrication. I do test heat pumps in the winter as they are designed to work in lower temperatures. If a unit must be tested in the winter, it should only be done by a licensed HVAC contractor. For more info check out: [url]http://www.inspect-ny.com/aircond/aircond08.htm[/url]
Old 12/6/07, 9:01 PM
It's not a NACHI position--it's a [B]manufacturer's[/B] recommendation.
Old 12/8/07, 1:46 AM
klott's Avatar
klott klott is offline
We go by the Manufacturer's recommendations.
Old 12/9/07, 8:49 PM
David A. Andersen's Avatar
You can modify an HVAC unit to be run at any OA Temp.
However, you must be EPA certified and a qualified HVAC Tech at the least, and will have to pay extra for this service as it is not in the inspection standard.
You will likely have trouble getting a Mechanical Contractor to do this service. Your best bet is a qualified and certified HI.
Old 12/12/07, 12:45 AM
Dan Bowers, CMI Dan Bowers, CMI is online now
Simple answer - don't do it if temp has not been at least 60 degrees for past 24 hours. Can it be done - yes. As HI's do we do it - no.
Old 12/12/07, 3:16 AM
Frank G. Ross Frank G. Ross is offline
Double megga dittos here. I never start up the AC unit in the winter when temps have been below 65 degrees. I do check to see the AC unit has the proper size breaker, is clean, sitting on a level pad, has a disconnect near by, and things like that.
Pillar To Post Professional Home Inspection of SW Utah
Serving all of Iron and Washington Counties including the cities of St. George, Cedar City, Beaver, Brian Head, Duck Creek and more.
Check out our website www.pillarposthomeinspection.com
Growing our business by leaps and bounds every day!!
Frank G. Ross
Certified Home Inspector
C.T.R.
(Certified ~ Trained ~ Reliable)
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274
