AskNACHI.org » use of concrete forms for subfloor (posted by J.E. Millican)
Old 1/8/08, 11:21 AM
AskNACHI.org AskNACHI.org is offline
Automated messenger from AskNACHI.org
Please Note: AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default use of concrete forms for subfloor (posted by J.E. Millican)
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]J.E. Millican[/B] (from MOSES LAKE, WA 98837). [/ASKNACHI]1/8/2008
About a year ago, in early January of 2007 I became ill with what I thought may have been some form of the flu. After consulting my regular physician she referred me to another doctor. After seeing many specialists and with no apparent answers I eventually saw an allergist in September. By this time I had quit my job due to my inability to do much at all. My symptoms include extreme fatigue, headache, nausea, dizziness, bronchial problems, sneezing and weakness. I am now receiving early retirement (I am 62) and have filed for disability.
One of the things that the allergist suggested I do was have my house inspected, as I might be suffering from “sick house syndrome”. I did this and found that I had elevated levels of VOC’s, especially in my garage and master bedroom. I had someone pull up the carpet in the master bedroom and we again measured the VOC’s and found that they had risen. We also noticed that the plywood subfloor was made from what appeared to be 2’ x 8’ concrete forms that had been treated with some form of petroleum based substance.
Since the carpet was pulled up I am not able to spend much time at all in the room as my symptoms become worse quickly. I have since felt mostly worse if I am in the house. I have consulted with my attorney and he is attempting to find someone to take my case. I am looking for anyone who might be able to help me determine if they are aware of a similar situation and how it was resolved.
Sincerely,
J.E. Millican
Old 1/9/08, 12:47 PM
Brian E. Kelly's Avatar
Default Re: use of concrete forms for subfloor (posted by J.E. Millican)
Your attorney should be able to answer that question.
Old 1/9/08, 1:09 PM
Bob Elliott's Avatar
VOC’s
What does that stand for?
Old 1/9/08, 1:11 PM
Michael Larson's Avatar
[quote=relliott]VOC’s
What does that stand for?[/quote][url]http://www.epa.gov/iaq/voc.html[/url]
Old 1/9/08, 1:34 PM
Thanks ...Mike
Never saw that abreviation being used till now.
Old 1/9/08, 8:31 PM
jbettencourt jbettencourt is offline
Please Note: jbettencourt is a non-member guest and is in no way affiliated with InterNACHI or its members.
J.E.
The petroleum based substance you are referring to is form oil which is used to prevent the forms from sticking to the poured concrete. This oil is definetely toxic and a known carcinogen, when we apply it to our forms we are to wear respirators. I know this because I have been a Formsetter for the past seven years , forming and pouring foundations for residential and commercial construction. Any builder who used this plywood for a subfloor is an idiot ,and shouldn't be in construction if he doesn't realize that the form oil could be a health hazard. Good Luck and I hope you don't suffer any extended health problems.
Old 1/9/08, 10:21 PM
rwand1 rwand1 is offline
Is there any way to possibly seal the forms or encapsulate to stop the off gassing from the sub floor?
Have you considered installing a heat recovery ventilator to increase air changes in the house or those particular rooms?
Old 1/9/08, 10:27 PM
I did a quick Google search using the following..
"sealing to prevent VOC off gassing"
[url]http://www.cbrproducts.com/homeowners_faq_afm.html[/url]
[url]http://www.greenbuildingsupply.com/utility/showArticle/?objectID=116[/url]
[url]http://irc.nrc-cnrc.gc.ca/ie/cope/05-3-Vent_Design_e.html[/url]
Old 1/10/08, 7:56 PM
Form Release Agents Defining, selecting and applying concrete form release agents.
[url]http://www.precast.org/publications/mc/TechArticles/03_Winter_Form_Release_Agents.htm[/url]
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
