AskNACHI.org » Vapor Barrier in Crawel Space (posted by John Reiser)
Old 8/14/07, 5:49 PM
AskNACHI.org AskNACHI.org is offline
Automated messenger from AskNACHI.org
Please Note: AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Vapor Barrier in Crawel Space (posted by John Reiser)
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]John Reiser[/B] (from Vancouver, WA). [/ASKNACHI]
Hello,
Could you please tell me what the requirement is for Washington State, Clark county on the following:
Crawl Space: What is the percentage of dirt that may be left exposed? Does 100% of the dirt need to be covered with the plastic vapor barrier?
Thank you,
Old 8/14/07, 5:59 PM
Roy D. Cooke, Sr's Avatar
Default Re: Vapor Barrier in Crawel Space (posted by John Reiser)
[quote=AskNACHI.org][asknachi]This question was posted on [I]AskNACHI.org[/I] by [B]John Reiser[/B] (from Vancouver, WA). [/asknachi]
Hello,
Thank you,[/quote]
No idea if there is a regulation but I would say cover it all and have the plastic turn up the wall a few inches .
Tape all joints and where it is at the wall a small amount of sand works well to help seal the gap ( 2 inches high by 3 inches wide +or -.
I would also keep my vents closed tight all the time especially in the summer as the crawl space will be cooler then the out side air .
Out side air in summer is usually very high in humidity and this is not good in the crawl space .
If you have a smell or think it has a concern a dehumidifier could be a big asset.
I recommend a constant drain be hooked to the dehumidifier as it becomes a nuisance to have to dump the water out of them and usually gets forgotten.
An Automatic humidifier is a great thing you can set the Humidity level at 50% and it will do a great job .
Roy Cooke
Old 8/14/07, 6:23 PM
James R. Szczesny's Avatar
James R. Szczesny James R. Szczesny is offline
yes,100% coverage...vents open within 3 feet of every corner
Old 8/14/07, 6:35 PM
[quote=jszczesny]yes,100% coverage...vents open within 3 feet of every corner[/quote]
Unless what I have been readings is wrong the new way is to no longer vent crawl spaces as Warm air is usually high humidity and bringing this into a cooler Crawl space can add dampness to this area.
...... Cookie
Old 8/14/07, 8:22 PM
phinsperger's Avatar
You are correct Cookie that venting crawl spaces in climates such as Washington are bad building science. However, some jusisdictions are simply not caught with the latest building science and may still require ventilation.
Old 8/14/07, 9:15 PM
Bruce A. King's Avatar
Ventilation very important around here unless the ground is completely sealed off. Then you risk moisture in the insulation and floor system depending on how the house is used, conditioned, height above ground, surrounding terrain, ground water etc. If you seal one up you better have a commercial type dehumidifier in there in most cases.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 8/16/07, 12:29 AM
jbreazeale jbreazeale is offline
Please Note: jbreazeale is a non-member guest and is in no way affiliated with InterNACHI or its members.
The Mississippi climate is very similar to S.C. Generally, in the coastal plains area from Virginai to Texas, unless you are going to have a completely sealed and conditioned crawl space, you had better leave those vents open. Closing the vents in a hot and humid climate will not keep water vapor from entering, even with a good vapor barrier. Better to have the air moving. How one handles this problem is dependent to a large degree upon one's climate. If winters are rather mild but extremely wet, closing off vents may be a good idea. One solution that works very well is to install a fan with a continuous duty motor at the access.
When it comes to crawl space ventilation, you will never find full agreement among home inspectors. But the best solution for most climates is the sealed crawl space. This involves some changes, some expense, and may not be practical in all cases, especially if the home is without central heating or air conditioning. In a sealed crawl space, the vapor barrier is extended over the inside of the curtain wall from the top, and draped over the ground vapor barrier. All seams are taped. A supply duct is installed through the floor, and the return air is whatever squeezes through the cracks. If the crawl space is large, the volume of free air space may dictate a larger air conditioning/heating unit. This is where upgrading a home to a sealed crawl space can become expensive or cost-prohibitive.
Old 8/16/07, 12:34 AM
I forgot to mention that the band joist in sealed and conditioned crawl spaces are insulated, the best method being spray foam which will also cover the top of the 6 mil plastic covering the curtain wall. Sorry 'bout that!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
