AskNACHI.org » warped siding (posted by Mindy smith)
Old 3/11/08, 6:06 PM
AskNACHI.org AskNACHI.org is offline
Automated messenger from AskNACHI.org
Please Note: AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default warped siding (posted by Mindy smith)
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]Mindy smith[/B] (from Vancouver WA). [/ASKNACHI]Hi Im looking for pictures of warped siding. Hardi plank or similar siding. what degree of warping should require replacement? thank you! Mindy
Old 3/11/08, 8:54 PM
Troy Farmer's Avatar
Troy Farmer Troy Farmer is offline
Default Re: warped siding (posted by Mindy smith)
Mindy many factors come in to play when deciding to replace existing siding,
one obvious one would be has water penetrated behind the siding that caused the warping? or is the siding rotten/warped from Wood Destroying Organism's this is why it would be in your best interest to hire a INACHI inspector to make further evaluation on your existing siding, here is James in Vancouver that would be more than happy to assist you further.
You should also know that he uses thermal imaging to further address any moisture problems you may have if any.
[URL="http://www.inspectionfirm.com/index.htm"]http://www.inspectionfirm.com/index.htm[/URL]
[B]What are the advantages of Hardie® products? [/B]
[LIST][*]It doesn't give in to the elements like wood can. There's [B]no rotting, warping, buckling or swelling.[/B] It withstands hail and flying debris from hard winds and storms.[*]It [B]holds paint much better than wood[/B], which means you don't have to paint as often and your home looks better, longer![*]It's impervious to termites and other wood-eating insects.[/LIST][B]Hardiplank® and Hardipanel®[/B] both come with a [B]50 year limited transferable warranty[/B] against rotting, warping or swelling. That's peace of mind. The [B]cement board[/B] composition of James Hardie® siding makes it the most fire-resistant building material money can buy. That could protect the part of your home that matters to you most: your family.
Troy Farmer
Presidential Inspections LLC
Chapter President Southern Idaho
PO Box 2144
Eagle, Idaho 83616
208-573-5300
http://www.presidentialinspection.com
http://info@presidentialinspection.com
"He who can, does. He who can’t, teaches"
"Where would we be without Teachers"
Old 3/11/08, 10:09 PM
James Fronsdahl James Fronsdahl is offline
[FONT=Calibri][SIZE=3]Hello Mindy;[/SIZE][/FONT]
[FONT=Calibri][SIZE=3]I have inspected many homes in your neighborhood, and live only a few miles away. Fiber cement board “Hardi”, installed per manufactures guidelines can look warped for many reasons most of which do not affect the integrity of the protective cladding and a few that have devastating effects. However, without actually seeing it in person a diagnosis is hard to make. I can tell you that I have yet to see a “Hardi” installation meet the exact guidelines. I see your home was just built in 2006 so you should have legitimate concerns. If you wish to call me for a free phone consultation I have questions to ask that may assist you.[/SIZE][/FONT]
[FONT=Calibri][SIZE=3]Looking forward to speaking with you,[/SIZE][/FONT]
[FONT=Calibri][SIZE=3]James Fronsdahl[/SIZE][/FONT]
[FONT=Calibri][SIZE=3]Associated Inspection Firm, Inc.[/SIZE][/FONT]
[FONT=Calibri][SIZE=3]360-546-2093[/SIZE][/FONT]
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
