AskNACHI.org » Warping milled logs, bow in wall, water runs
Old 2/25/11, 1:41 AM
Unregistered
Guest
Posts: n/a
Default Warping milled logs, bow in wall, water runs
Hello,
I was looking on your site for information related to my own log homes problems. So far i am unable to educate myself on the type or severity of the problems in my home.
My home is made of 9” milled cedar, triple tongue and groove, no chinking. House is 2.5 years old, and getting progressively worse.
I have numerous logs that have warped to the extent of the tongue and groove being completely separated. (you can stick a screwdriver under the top logs tongue) Also at the front of the house the wall is bowed quite a bit from top to bottom. As well numerous logs near the top of the wall are also out of there tongue and groove, although they are not warped. They have just risen out of place. Also some log butts have pulled apart. Many doors had to be realigned.
I also have throughout the interior of the house small water runs from between logs butting together as well as where they are sandwiched together. The builder explains it is condensation and not to worry. There are hundreds of these water runs.
The builder is not about to do anything about the problems, and explains they are all normal with log houses. I have not however found any similar examples.
Its hard to describe the conditions adequately, I can send photos, if you are able to help. It may also be a good section to add to the course if others are having similar problems.
Thanks very much for any help,
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
