AskNACHI.org » water and septic inspections
Old 7/16/09, 11:10 AM
Unregistered
Guest
Posts: n/a
Default water and septic inspections
what can be expected from a water test and septic inspection?
Find an InterNACHI certified Rhode Island Home Inspector (and anywhere else in North America)
Old 9/12/09, 3:34 PM
Robert Hess Robert Hess is offline
Default Re: water and septic inspections
With water testing you can expect to test for Bacteria (e-coli, coliform), Lead, and Nitrate-Nitrites.
Old 9/12/09, 3:35 PM
With septic sytems there are different tests, ranging from simple dye tests, to septic load tests which are more complicated
Old 9/12/09, 4:19 PM
mnahrgang's Avatar
It depends on your location and the local requirements/Standards of Practice.
Mark Nahrgang
www.HeyMark.info
Old 9/17/09, 11:39 AM
David A. Selman David A. Selman is offline
Here in Texas, Selman Home Inspection inspects septic systems using the "load test" method, inspection of the tanks (if accessible), using a "sludge judge" to determine if a tank needs to be pumped out, and a visible inspection of the drain field.
Regards,
David Selman
Selman Home Inspections
www.selmanhomeinspections.com
Old 9/17/09, 2:37 PM
David P. Valley's Avatar
http://www.masscertifiedhomeinspections.com/?D=75
http://www.masscertifiedhomeinspections.com/?D=57
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
