AskNACHI.org » wet rotten planks under roof
Old 5/22/09, 6:16 PM
John Caulk
Guest
Posts: n/a
Default wet rotten planks under roof
Hello,
I am searching for specific documentation re: proper procedure for roofing a wet, rotted roof in Philadelphia, PA. to refute the allegations of a roofer that their work on a project was satisfactory.
A roofing contractor took off an old, low-sloped roof, said all of the planking underneath the roof was rotted, warped (curled) and entirely soaked with water, They installed sheathing directly onto this substrate and put a new roof on top of this. In the contract, they said they would remove any rotten wood @ x cost / square foot. I'm concerned that the "rotted"/soaked planking will attract WDO, breed mold and advance the rot into the structural members of the roof. They only offer a manufacturer's warrantee on paper. I am afraid the roof will have to be completely removed at a greater cost, the manufacturer's warrantee will be voided and that the two young children living directly below the roof will be affected by possible mold growth and dispersion.
Thank you for your time,
John
Find an InterNACHI certified Hawaii Home Inspector (and anywhere else in North America)
Old 6/28/09, 5:51 PM
Michael J. Merino's Avatar
Michael J. Merino Michael J. Merino is offline
Default Re: wet rotten planks under roof
John, I think you should remind them that the contract included removal of the wet rotted wood. regardless of whether it is a proper install or not, a contract is a contract. I believe that the wood should have been removed before the new roof was installed.
Michael Merino
Merino's Home Inspection & Education Inc.
"Not just an Inspection, an Education"SM
Phone/Fax 708~535~6057
Old 6/28/09, 7:22 PM
David P. Valley's Avatar
If the sheathing was simply wet and it did not get damaged from the continuous moisture, it should be fine. But if this sheathing is compromised, curled, or delaminated, it should have been replaced before the shingles were applied. The shingle hardware will not hold on compromised sheathing.
Do you have images of the underside?
Old 6/28/09, 7:27 PM
I believe he stated in the post "A roofing contractor took off an old, low-sloped roof, said all of the planking underneath the roof was rotted, warped (curled) and entirely soaked with water"
Michael Merino
Old 6/28/09, 7:29 PM
[QUOTE=mmerino;530974]I believe he stated in the post "A roofing contractor took off an old, low-sloped roof, said all of the planking underneath the roof was rotted, warped (curled) and entirely soaked with water"[/QUOTE]
What one person calls rot does not mean it actually is.
Images will confirm this.
Old 6/28/09, 10:27 PM
[QUOTE=John Caulk;519331]Hello,
John[/QUOTE]
The rot may have already advanced into the framing but since the rotted/soaked sheathing wasn't removed, that may not be known.
It sounds like a very poor choice of application methods.
Getting a look under the roof deck is going to be important to get the information you seek.
What type of roofing materials was installed on the low slope?
After that, State Licensing Boards and Roofing Manufacturers (for installation instructions) may be helpful.
Larry Kage, CMI
231 929 3525
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274
