AskNACHI.org » white bugs in toilet tank
Old 11/22/10, 12:36 PM
Unregistered
Guest
Posts: n/a
Default white bugs in toilet tank
does anyone know what those tiny white bugs are in my toilet tank.
Need a home inspection in New Jersey? Check out InterNACHI's listing of New Jersey certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/23/10, 6:39 PM
William Warner's Avatar
William Warner William Warner is offline
Default Re: white bugs in toilet tank
Without further details it is extremely difficult to determine identification.
Common nuisance pests inside the home include book lice (which are not true lice)
http://ento.psu.edu/extension/factsheets/booklice
and are often tiny almost microscopic and white or translucent in color and attracted to moist/humid environments.
CAUTION!!! This post in no way indicates positive identification.
Taking samples of specimens to your local cooperative extension office or university entomology department may help with proper identification and remedy and is strongly encouraged.
Visit the InterNACHI Awards web portal here
Blessed are the blissfully ignorant... for they shall be easily led...
Old 11/23/10, 7:18 PM
Tom Leahy Tom Leahy is offline
I had a friend crying about little white bugs in his toilet tank and they were found to be springtails. As William posted before, to many possibilities with not enough info. Could be spider mites and so on and so on. If they are ONLY in the tank, look up springtails and see if they resemble each other.
Fort Worth Home Inspector
Dallas Home Inspector
Old 11/24/10, 8:28 AM
Unregistered
Guest
Posts: n/a
Hi, thanks for your reply, I did look up springtails and it doesn't appear the same as what I have, which are white and maybe 1/16 inch. I was hoping to identify it before I bleached out the tank again, but my cooperative extension does not do testing for water. anyway, I am hoping someone out there has had the same problem and can help.
thanks everyone.
Old 11/24/10, 10:25 PM
Sean Fogarty's Avatar
Maybe its time to clean your toilet perhaps?
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 11/25/10, 2:57 PM
[QUOTE=Unregistered;714042]Hi, thanks for your reply, I did look up springtails and it doesn't appear the same as what I have, which are white and maybe 1/16 inch. I was hoping to identify it before I bleached out the tank again, but my cooperative extension does not do testing for water. anyway, I am hoping someone out there has had the same problem and can help.
thanks everyone.[/QUOTE]
Testing the water won't determine what insects you have and is not what I had recommended you do... you would need to take a sample of THE INSECT SPECIMENS to them... collect several specimens in a vial and take them to the cooperative extension office. If they (the employees there) are worth anything, they can help you with identification.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
