AskNACHI.org » how wide should a parapet wall be (posted by clarence kluesner)
Old 10/18/07, 7:47 PM
AskNACHI.org AskNACHI.org is offline
Automated messenger from AskNACHI.org
Please Note: AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default how wide should a parapet wall be (posted by clarence kluesner)
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]clarence kluesner[/B] (from bloomington wis). [/ASKNACHI]how wide shoud a parapet wall be
Old 10/18/07, 10:03 PM
John Nosworthy John Nosworthy is offline
Default Re: how wide should a parapet wall be (posted by clarence kluesner)
Only as wide as it needs to be to perform, otherwise you are wasteing materials.
Old 10/18/07, 11:13 PM
Barry Adair's Avatar
Sometimes width and height are confused.
If this is the case 39" above the roof surface is considered a safe working height.
[URL="http://www.safetyresources.com/safety_bulletin_7_06_parapet.aspx"]http://www.safetyresources.com/safety_bulletin_7_06_parapet.aspx[/URL]
Many do not come close to this accepted standard.
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 10/19/07, 6:28 AM
rwand1 rwand1 is offline
How wide should a parpet be?
That depends on the age of the building. Century building parpets tend to be as wide as the outer wall. If the outer wall is stone rubble I hope the parapet is as wide. If the outer wall is double brick the parpet should be as wide.
Old 10/19/07, 11:44 AM
[COLOR=blue]They require a
minimum of 1/4 per foot fall. The parapet/gutter decision may be
influenced by your exterior material. Parapets require attention
to detail so they are structurally sound. The exterior wall will
be subjected to very different weather conditions above the roof
line. The inside of parapets are typically roofed with the same
material as the roof with a metal wall cap and fascia. The
dimension of the fascia is determined by what needs to be covered
up to overlap the finish exterior surface. Parapets would
typically have roof drains with overflow scuppers, sufficient
pitch to shed elsewhere, or through-the-parapet piping usually to
a conductor head and downspout. [/COLOR]
[COLOR=blue]Marcel:)
[/COLOR]
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
