AskNACHI.org » Window Safety
Old 2/21/11, 6:20 PM
Unregistered
Guest
Posts: n/a
Default Window Safety
I am wanting to build an elevated room where a majority of one wall is glass (sits about 6-10 feet above finished grade). The windows won't open, but they will be very close to the floor, I would guess 12 inches or so from the floor. Due to the window height above grade outside, I'm guessing we'll need some sort of safety glass to prevent falling in the event the glass breaks. We do not want to put a railing or bar on the outside of the window as it will obstruct the views we are trying to accentuate.
My question is, what type of glass do we need to purchase to ensure these windows are safe? Or do we simply need tempered glass because they are so close to the floor? What is the minimum height from floor to the bottom of the window sill to where we could put a standard, non-opening window. Right we are planning on windows about 4 feet wide by 5 feet tall. Thank you in advance for your assistance.
Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/21/11, 8:23 PM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is offline
Default Re: Window Safety
There is more to it then what you are suggesting. Maybe a location where you are would be nice. Is this roof closed off and do the windows / window act as a means of egress? Which way do the windows face. How much overhang is there. What is your building comprised of, wood frame, CBS, EIFS?....
Answer some of these and maybe we can get you started in the right direction.
Comprehensive Building Consultants
Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection.
Donate here:
or send checks to the
Fl Home and Insurance Inspector Chapter
1103 W Hibiscus Blvd Ste 311
Melbourne, Fl 32901
Old 2/21/11, 9:14 PM
Bob Elliott's Avatar
These two illustrations should help you out ,guest.
window-safety-safety-glass-protective-bar.jpg   window-safety-safety-glass-copy.jpg
Old 2/22/11, 9:30 AM
Brett
Guest
Posts: n/a
[QUOTE=rhensel;750942]There is more to it then what you are suggesting. Maybe a location where you are would be nice. Is this roof closed off and do the windows / window act as a means of egress? Which way do the windows face. How much overhang is there. What is your building comprised of, wood frame, CBS, EIFS?....
Answer some of these and maybe we can get you started in the right direction.[/QUOTE]
We're located in rural Missouri (Stone County, the Ozarks), and our county planning and zoning said we don't have building codes or inspectors. It is a wood frame structure, with 1' 6" of roof overhang. These windows I'm describing will not be egress. The windows face north-west. Hope that helps, thanks for everything so far.
-Brett
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
